跳转到主内容
Olympus Pen E-PL7 Back Case Replacement
你所需要的
  1. Olympus Pen E-PL7 Back Case Replacement, Back Case: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws on the bottom of the camera.
  2. Olympus Pen E-PL7 Back Case Replacement: 步骤 2 中的图像 1,1
    • Remove the two 4 mm reverse threaded Phillips screws from the bottom of the camera.
    • Reverse threaded screws tighten counter clockwise and loosen clockwise.
  3. Olympus Pen E-PL7 Back Case Replacement: 步骤 3 中的图像 1,1
    • Remove the two 4 mm Phillips screws under the HDMI port cover.
  4. Olympus Pen E-PL7 Back Case Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the left hand grip.
  5. Olympus Pen E-PL7 Back Case Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the right hand grip.
  6. Olympus Pen E-PL7 Back Case Replacement: 步骤 6 中的图像 1,1
    • Flip open the LCD.
    • Use a Phillips #00 screwdriver to remove the 2 mm screw beneath the LCD assembly.
  7. Olympus Pen E-PL7 Back Case Replacement: 步骤 7 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
  8. Olympus Pen E-PL7 Back Case Replacement: 步骤 8 中的图像 1,1
    • Remove the lens mount with tweezers.
  9. Olympus Pen E-PL7 Back Case Replacement: 步骤 9 中的图像 1,1
    • Use tweezers to remove the inner metal ring.
  10. Olympus Pen E-PL7 Back Case Replacement: 步骤 10 中的图像 1,2 Olympus Pen E-PL7 Back Case Replacement: 步骤 10 中的图像 2,2
    • Use tweezers to remove the two springs lying beneath the inner metal ring.
  11. Olympus Pen E-PL7 Back Case Replacement: 步骤 11 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws.
  12. Olympus Pen E-PL7 Back Case Replacement: 步骤 12 中的图像 1,1
    • Remove the two 4 mm Phillips screws.
  13. Olympus Pen E-PL7 Back Case Replacement: 步骤 13 中的图像 1,3 Olympus Pen E-PL7 Back Case Replacement: 步骤 13 中的图像 2,3 Olympus Pen E-PL7 Back Case Replacement: 步骤 13 中的图像 3,3
    • Press and hold the lens release button while using tweezers to remove the lens hook.
    • Use tweezers to remove the spring underneath the lens hook.
  14. Olympus Pen E-PL7 Back Case Replacement: 步骤 14 中的图像 1,3 Olympus Pen E-PL7 Back Case Replacement: 步骤 14 中的图像 2,3 Olympus Pen E-PL7 Back Case Replacement: 步骤 14 中的图像 3,3
    • Use tweezers to remove the metal clip from the external flash mount.
  15. Olympus Pen E-PL7 Back Case Replacement: 步骤 15 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the external flash port.
  16. Olympus Pen E-PL7 Back Case Replacement: 步骤 16 中的图像 1,2 Olympus Pen E-PL7 Back Case Replacement: 步骤 16 中的图像 2,2
    • Remove the second external flash clip with tweezers.
  17. Olympus Pen E-PL7 Back Case Replacement: 步骤 17 中的图像 1,2 Olympus Pen E-PL7 Back Case Replacement: 步骤 17 中的图像 2,2
    • Remove the external flash port casing to expose five more screws.
  18. Olympus Pen E-PL7 Back Case Replacement: 步骤 18 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws.
    • Remove the 2 mm Phillips screw.
  19. Olympus Pen E-PL7 Back Case Replacement: 步骤 19 中的图像 1,1
    • Remove the two 3.8 mm Phillips screws from the sides of the external flash connector.
  20. Olympus Pen E-PL7 Back Case Replacement: 步骤 20 中的图像 1,1
    • Gently pull the back case away from the camera.
    • Do not attempt to remove the back case, as it is attached to the camera by a ribbon cable.
  21. Olympus Pen E-PL7 Back Case Replacement: 步骤 21 中的图像 1,3 Olympus Pen E-PL7 Back Case Replacement: 步骤 21 中的图像 2,3 Olympus Pen E-PL7 Back Case Replacement: 步骤 21 中的图像 3,3
    • To remove the ribbon holding the back case to the camera, use the pointed end of a spudger to flip back the top bar on top of the ZIF connector.
  22. Olympus Pen E-PL7 Back Case Replacement: 步骤 22 中的图像 1,3 Olympus Pen E-PL7 Back Case Replacement: 步骤 22 中的图像 2,3 Olympus Pen E-PL7 Back Case Replacement: 步骤 22 中的图像 3,3
    • Use tweezers to pull the ribbon out of the connector.
    • Remove the back case.
结论
3等其他人完成本指南。
Kelsea Weber
于11/12/15注册
19,873 声望
创作了32篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
一条评论
Loads of screws that don’t need to be removed just to remove the rear case.
Omit step 3,
Omit steps 6 to 13
Omit step 18
Take great care not to pull on ribbon cables
Rod Heeley - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 30
总计 3,228
