跳转到主内容
Olympus C-765 LCD Screen Replacement
你所需要的
  1. Olympus C-765 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Olympus C-765 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Olympus C-765 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Remove all the screws using your Phillips #00 holding the back plate in place. This includes:
    • On the Back: Unscrew the 4mm screw to the right of the viewfinder.
    • On the Bottom:
    • Unscrew the 3mm screw in the top left corner.
    • Unscrew the four 3mm screws under the battery cover.
    • On the Right Side: Unscrew the one 3mm screw holding the right-side panel.
    • On the Left Side: Unscrew the two 2mm screws holding the left-side panel.
  2. Olympus C-765 LCD Screen Replacement: 步骤 2 中的图像 1,2 Olympus C-765 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • After you remove the back cover:
    • Gently pull the two ribbon cables out of their sockets.
    • Gently disconnect the white cable.
  3. Olympus C-765 LCD Screen Replacement: 步骤 3 中的图像 1,3 Olympus C-765 LCD Screen Replacement: 步骤 3 中的图像 2,3 Olympus C-765 LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Peel the black tape off the back of the LCD.
    • Using the Phillips #00 remove the four 3mm screws on the LCD bracket.
    • Remove the two 2mm screws from the top of the bracket.
    • Use a spudger to pop the LCD screen out of the camera’s backplate.
    • When the bracket comes off, the buttons from the top section may fall out of place. If this happens then put them back in the position they were in.
结论
2等其他人完成本指南。
Mason Morgan
于04/05/11注册
118 声望
创作了6篇指南
团队
Cal Poly, Team 12-33, Maness Spring 2011 Cal Poly, Team 12-33, Maness Spring 2011 的会员
CPSU-MANESS-S11S12G33
3 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 3,143
