跳转到主内容
Oculus Rift Control Box Motherboard Replacement
你所需要的
  1. Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: 步骤 1 中的图像 1,3 Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: 步骤 1 中的图像 2,3 Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: 步骤 1 中的图像 3,3
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
  2. Oculus Rift Control Box Motherboard Replacement: 步骤 2 中的图像 1,3 Oculus Rift Control Box Motherboard Replacement: 步骤 2 中的图像 2,3 Oculus Rift Control Box Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
  3. Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: 步骤 3 中的图像 1,3 Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: 步骤 3 中的图像 2,3 Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: 步骤 3 中的图像 3,3
    • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
    • When the DVI connector has cleared the casing, lift the motherboard.
    • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
    • When reassembling the device, ensure that all of the wires are clear of the buttons.
  4. Oculus Rift Control Box Motherboard Replacement: 步骤 4 中的图像 1,3 Oculus Rift Control Box Motherboard Replacement: 步骤 4 中的图像 2,3 Oculus Rift Control Box Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
    • Do so for both of the wires attached to the motherboard.
    • Now fully separate the motherboard from the control box casing.
结论
Audrey Chan
于01/12/15注册
201 声望
创作了2篇指南
团队
Cal Poly, Team 70-5, Forte Winter 2015 Cal Poly, Team 70-5, Forte Winter 2015 的会员
CPSU-FORTE-W15S70G5
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,078
