简介
Once uncovered, you can see that the battery takes up the most real-estate inside of the device. The battery is very securely glued in so you will need to be forceful but also extremely careful when removing it.
你所需要的
Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
Using the blue plastic opening tool, place the lip of the tool underneath the battery as seen in the photo.
When the battery seems loose enough, use the blue plastic opening tool to lift the battery from the device.
The white wire is for temperature line. What about the green wire? I have generic battery almost same size ang xapacity but it had only 3 wires, red black ang white. Green is missing
Using a soldering iron, desolder the four wires from the motherboard.
Once the wires are free from the motherboard, your battery should be free to remove from your device.
Where can I buy a replacement battery??
Where can I buy a replacement battery for my Nvidia tablet??
Aliexpress -[L508 3,8 V 3,7 V 5000 mAh [3565152] PLIB; polímero de iones de litio/Li-ion batería para tablet pc de autonomía, carga de dispositivos, corrección keystone automática, e-book; BL-T17 celular
Those replacement batteries only have 2 or 3 wires. Any ideas since the one on the Shield has 4 wires?
15等其他人完成本指南。
7条评论
Cannot find a replacement battery anywhere, any information would be appreciated.
Thanks!
Carl
Here: to aliexpress
I just happened to be looking because my battery life is atrocious. And here's the forum where I found it. They have other links too if you want to try them out.
I just happened to be looking into this myself. I found a forum with many links that can be found by searching “Finding Replacement Battery in 2017?” . The thread is on XDA-developers.com. This is a link that works: on de.aliexpress.com
Good luck. As there is no convincing upgrade from the Shield K1, I might do this too. Other people noted that you need the little PCB attached to the original battery to solder it onto the bare replacement battery.
Hi James
Thanks for your tuto, but now (2019/12) it’s useless because there’s no more genuine battery on the market.
So, one tuto with “compatible” battery (and cables connecting) would be appreciated !
Excuse for my poor english !
Hello man where I can buy the battery
hangchetha - 回复
