跳转到主内容
NuWave Brio 37001 Rubber Feet Replacement
  1. NuWave Brio 37001 Rubber Feet Replacement, Rubber Feet: 步骤 1 中的图像 1,2 NuWave Brio 37001 Rubber Feet Replacement, Rubber Feet: 步骤 1 中的图像 2,2
    • Unplug your NuWave appliance and ensure it has not been used within the last 20 minutes so that it is properly cooled down. Following this guide with an appliance that is still hot or powered on may result in injury.
    • Remove the basket, and flip the air fryer upside down so its feet are accessible.
  2. NuWave Brio 37001 Rubber Feet Replacement: 步骤 2 中的图像 1,2 NuWave Brio 37001 Rubber Feet Replacement: 步骤 2 中的图像 2,2
    • Using gentle force, pull out the damaged leg or legs.
    • If you are unsure which leg or legs need replacement, try flipping the air fryer back over again. If the legs are uneven, the air fryer will rock diagonally. The bad leg is one of the two corners that go up and down when it rocks.
    • If you still have the original packaging, the air fryer may have come with a sachet of replacement feet.
结论
If your Air Fryer is still unbalanced, identify the additional bad leg and repeat the process!
另外一个人完成了本指南。
Ian Moore
于03/01/23注册
115 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 114
