跳转到主内容
NuWave Brio 37001 Heating Plate Replacement
你所需要的
  1. NuWave Brio 37001 Heating Plate Replacement, Heating Plate: 步骤 1 中的图像 1,1
    • Unplug your NuWave appliance and ensure it has not been used within the last 20 minutes so that it is properly cooled down. Following this guide with an appliance that is still hot or powered on may result in injury.
    • Remove the basket from the NuWave's tray.
  2. NuWave Brio 37001 Heating Plate Replacement: 步骤 2 中的图像 1,2 NuWave Brio 37001 Heating Plate Replacement: 步骤 2 中的图像 2,2
    • Rest your appliance upside down, with the digital screen facing your work surface.
    • Take caution in flipping your appliance. Excessive force may cause components to break.
    • Remove the six 12 mm screws located around the edge of the bottom lid using a Phillips #1 screwdriver.
    • Remove four 10 mm screws using a Phillips #1 screwdriver.
  3. NuWave Brio 37001 Heating Plate Replacement: 步骤 3 中的图像 1,3 NuWave Brio 37001 Heating Plate Replacement: 步骤 3 中的图像 2,3 NuWave Brio 37001 Heating Plate Replacement: 步骤 3 中的图像 3,3
    • Use your finger to flip up each small metal tab located around the heating plate.
    • The plate may fall when all tabs have been flipped up.
    • Photos #2 and #3 both display an additional piece removed, which lines the edge of the basket area. Removing this is entirely unnecessary and included solely for the visibility of this guide.
  4. NuWave Brio 37001 Heating Plate Replacement: 步骤 4 中的图像 1,1
    • After flipping each tab, remove the plate by pushing downwards on its surface.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 28
总计 328
