跳转到主内容
NuVision Duo 11 Battery Replacement
你所需要的
  1. NuVision Duo 11 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the flat end of a nylon spudger in the gap between the cover and the rest of the device.
    • Slide the spudger down each side until you hear numerous clicks.
    • Remove the back panel from the tablet.
  2. NuVision Duo 11 Battery Replacement, Battery: 步骤 2 中的图像 1,2 NuVision Duo 11 Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Carefully remove any pieces of electrical tape that may be adhered to the battery.
    • The tape may be adhered to wires; be sure to pull up the tape slowly.
  3. NuVision Duo 11 Battery Replacement: 步骤 3 中的图像 1,1
  4. NuVision Duo 11 Battery Replacement: 步骤 4 中的图像 1,1
    • Gently peel the battery from the front case.
    • You will be met with some resistance, so it is critical that you are very careful.
    • DO NOT puncture or bend the battery. It may explode or leak toxic chemicals.
结论
Gavin Amaral
于03/16/23注册
377 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-1, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-1, Ryckebusch Spring 2023 的会员
UMASSD-RYCKEBUSCH-S23S7G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 26
总计 263
