跳转到主内容
Nook Simple Touch with GlowLight Screen Replacement
你所需要的
  1. Nook Simple Touch with GlowLight Screen Replacement, Power Button: 步骤 1 中的图像 1,1
    • Place the Nook with the screen facing down.
  2. Nook Simple Touch with GlowLight Screen Replacement: 步骤 2 中的图像 1,1
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
  3. Nook Simple Touch with GlowLight Screen Replacement: 步骤 3 中的图像 1,1
    • Using your fingers, gently remove the power button.
  4. Nook Simple Touch with GlowLight Screen Replacement, Back Cover: 步骤 4 中的图像 1,1
    • Remove the single screw using a T4 Torx screwdriver.
  5. Nook Simple Touch with GlowLight Screen Replacement: 步骤 5 中的图像 1,1
    • Slide the back cover down towards you in the direction of the charging port.
  6. Nook Simple Touch with GlowLight Screen Replacement, Battery: 步骤 6 中的图像 1,2 Nook Simple Touch with GlowLight Screen Replacement, Battery: 步骤 6 中的图像 2,2
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
  7. Nook Simple Touch with GlowLight Screen Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Remove eleven screws from the motherboard using the T4 screwdriver.
  8. Nook Simple Touch with GlowLight Screen Replacement: 步骤 8 中的图像 1,3 Nook Simple Touch with GlowLight Screen Replacement: 步骤 8 中的图像 2,3 Nook Simple Touch with GlowLight Screen Replacement: 步骤 8 中的图像 3,3
    • Disconnect the orange ribbon cable from the motherboard.
    • Using your fingers, gently lift the motherboard from the display.
  9. Nook Simple Touch with GlowLight Screen Replacement, Screen: 步骤 9 中的图像 1,2 Nook Simple Touch with GlowLight Screen Replacement, Screen: 步骤 9 中的图像 2,2
    • Insert the iFixit opening tool between the display and the front case.
    • Gently move to iFixit opening tool around the perimeter to release the set of tape strips.
  10. Nook Simple Touch with GlowLight Screen Replacement: 步骤 10 中的图像 1,2 Nook Simple Touch with GlowLight Screen Replacement: 步骤 10 中的图像 2,2
    • Turn the display over. Pry the display bezel from the display assembly with the iFixit opening tool.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 29
总计 1,065
