跳转到主内容
加入维修社区 - 创建账户
Nokia 6085h Front LCD Display
你所需要的
  1. Nokia 6085h Front LCD Display, Battery: 步骤 1 中的图像 1,1
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
    询问修复机器人
    添加评论
  2. Nokia 6085h Front LCD Display: 步骤 2 中的图像 1,1
    • Remove the phone's battery.
    询问修复机器人
    添加评论
  3. Nokia 6085h Front LCD Display, Front LCD Display: 步骤 3 中的图像 1,3 Nokia 6085h Front LCD Display, Front LCD Display: 步骤 3 中的图像 2,3 Nokia 6085h Front LCD Display, Front LCD Display: 步骤 3 中的图像 3,3
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
    • Make sure to disconnect each of the five clips before proceeding to the next step.
    • There are two clips on each side of the phone and one on the top.
    询问修复机器人
    添加评论
  4. Nokia 6085h Front LCD Display: 步骤 4 中的图像 1,2 Nokia 6085h Front LCD Display: 步骤 4 中的图像 2,2
    • Remove the four 3.2 mm screws from the front panel using a T6 Torx screwdriver.
    • The fourth screw is located under a fold in the ribbon cable.
    询问修复机器人
    添加评论
  5. Nokia 6085h Front LCD Display: 步骤 5 中的图像 1,3 Nokia 6085h Front LCD Display: 步骤 5 中的图像 2,3 Nokia 6085h Front LCD Display: 步骤 5 中的图像 3,3
    • Starting in the lower right corner, slowly begin to lift the tape that is holding down the front LCD and cables.
    • Be careful around the two ribbon cables attached to the tape. These cables are fragile.
    • Lift the tape from the board.
    询问修复机器人
    添加评论
  6. Nokia 6085h Front LCD Display: 步骤 6 中的图像 1,1
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
    询问修复机器人
    添加评论
  7. Nokia 6085h Front LCD Display: 步骤 7 中的图像 1,3 Nokia 6085h Front LCD Display: 步骤 7 中的图像 2,3 Nokia 6085h Front LCD Display: 步骤 7 中的图像 3,3
    • Using a plastic opening tool, slowly pry the LCD display from the bottom, releasing it from the glue that is holding it to the board.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 4-46, Amido Fall 2010 Cal Poly, Team 4-46, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G46
4 名成员
创作了28篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 40
总计 1,660
