你所需要的
Slide the back cover down with your thumb.
*Note: the battery cover is not shown in this picture
On some models, the front case is screwed down from the back. Follow steps 5 and 6 FIRST to remove the camera cover and two T6 screws, before removing the faceplate.
Use the Spudger to gently pry up the edges of the front face plate
At the center of the faceplate edge below the music keys there is a small latch on each side.
Gently unsnap the back camera cover from the phone.
Lift the cover from the phone after it is unsnapped.
Unclip the ribbon plug located on the top of the LCD screen that connects it to the motherboard
6等其他人完成本指南。
