跳转到主内容
Nobis NB07 Speaker Replacement
你所需要的
  1. Nobis NB07 Speaker Replacement, Opening the case: 步骤 1 中的图像 1,1
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. Nobis NB07 Speaker Replacement: 步骤 2 中的图像 1,3 Nobis NB07 Speaker Replacement: 步骤 2 中的图像 2,3 Nobis NB07 Speaker Replacement: 步骤 2 中的图像 3,3
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Nobis NB07 Speaker Replacement, Replacing the battery: 步骤 3 中的图像 1,3 Nobis NB07 Speaker Replacement, Replacing the battery: 步骤 3 中的图像 2,3 Nobis NB07 Speaker Replacement, Replacing the battery: 步骤 3 中的图像 3,3
    • Remove the tape holding the battery in place.
  4. Nobis NB07 Speaker Replacement: 步骤 4 中的图像 1,3 Nobis NB07 Speaker Replacement: 步骤 4 中的图像 2,3 Nobis NB07 Speaker Replacement: 步骤 4 中的图像 3,3
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. Nobis NB07 Speaker Replacement: 步骤 5 中的图像 1,1
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Nobis NB07 Speaker Replacement: 步骤 6 中的图像 1,2 Nobis NB07 Speaker Replacement: 步骤 6 中的图像 2,2
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
  7. Nobis NB07 Speaker Replacement, Removing the speaker: 步骤 7 中的图像 1,3 Nobis NB07 Speaker Replacement, Removing the speaker: 步骤 7 中的图像 2,3 Nobis NB07 Speaker Replacement, Removing the speaker: 步骤 7 中的图像 3,3
    • Remove the tape holding the speaker in its socket.
  8. Nobis NB07 Speaker Replacement: 步骤 8 中的图像 1,2 Nobis NB07 Speaker Replacement: 步骤 8 中的图像 2,2
    • After you remove the tape, remove the speaker from its socket. You can place the speaker on one side of the tablet to have more freedom.
    • Look for the place where the speaker's cables meet with the motherboard.
    • Annotate where which color goes to make the reassembly easier.
  9. Nobis NB07 Speaker Replacement: 步骤 9 中的图像 1,2 Nobis NB07 Speaker Replacement: 步骤 9 中的图像 2,2
    • Use a soldering iron to desolder the cables and extract the solder using a desoldering braid.
    • You can now remove the speaker.
结论
Daniel Gomero
于01/21/15注册
966 声望
创作了5篇指南
团队
USF Tampa, Team 5-5, Brown Winter 2015 USF Tampa, Team 5-5, Brown Winter 2015 的会员
USFT-BROWN-W15S5G5
3 名成员
创作了10篇指南
2条评论
How can I restore the memory on these tablets - were having problems with this tablet please help us
annievvtait07 - 回复
This is my favourite online game mahjong games online i have some time play.
conor mcgregor - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 237
