跳转到主内容
加入维修社区 - 创建账户
Nobis NB07 Battery Replacement
你所需要的
    1. Nobis NB07 Battery Replacement, Opening the case: 步骤 1 中的图像 1,1
      • Look towards the topside of the tablet, where the power button is located.
      • Insert a plastic opening tool in the crack between the two parts of the case.
      • Move it gently back and forth to open the case.
      询问修复机器人
      添加评论
    2. Nobis NB07 Battery Replacement: 步骤 2 中的图像 1,3 Nobis NB07 Battery Replacement: 步骤 2 中的图像 2,3 Nobis NB07 Battery Replacement: 步骤 2 中的图像 3,3
      • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
      • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
      询问修复机器人
      添加评论
    3. Nobis NB07 Battery Replacement, Replacing the battery: 步骤 3 中的图像 1,3 Nobis NB07 Battery Replacement, Replacing the battery: 步骤 3 中的图像 2,3 Nobis NB07 Battery Replacement, Replacing the battery: 步骤 3 中的图像 3,3
      • Remove the tape holding the battery in place.
      询问修复机器人
      添加评论
    4. Nobis NB07 Battery Replacement: 步骤 4 中的图像 1,3 Nobis NB07 Battery Replacement: 步骤 4 中的图像 2,3 Nobis NB07 Battery Replacement: 步骤 4 中的图像 3,3
      • Insert the flat end of the spudger tool in the crack beneath the battery.
      • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
      • This is a soft battery, so a little bending is expected.
      询问修复机器人
      添加评论
    5. Nobis NB07 Battery Replacement: 步骤 5 中的图像 1,1
      • After the battery is unglued, locate the cables that connect it to the motherboard.
      • Annotate where each color goes to make the reassembly easier.
      询问修复机器人
      添加评论
    6. Nobis NB07 Battery Replacement: 步骤 6 中的图像 1,2 Nobis NB07 Battery Replacement: 步骤 6 中的图像 2,2
      • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
      • Review the Ifixit soldering guide if you need help soldering.
      • You can now remove the battery.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
USF Tampa, Team 5-5, Brown Winter 2015 USF Tampa, Team 5-5, Brown Winter 2015 的会员
USFT-BROWN-W15S5G5
3 名成员
创作了25篇指南
1指南评论
where do you find that battery? tried searching by the numbers on it and nothing
Scott Tuttle - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 35
总计 3,691
