跳转到主内容
Nintendo Wii Remote Front Cover Plate and Batteries Replacement
你所需要的
  1. Nintendo Wii Remote Front Cover Plate and Batteries Replacement, Front Cover Plate and Batteries: 步骤 1 中的图像 1,2 Nintendo Wii Remote Front Cover Plate and Batteries Replacement, Front Cover Plate and Batteries: 步骤 1 中的图像 2,2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    my battery cover is different. The batteries are attached to the actual cover and come out when the back is removed.
    Kim Pearson - 回复
  2. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: 步骤 2 中的图像 1,1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: 步骤 3 中的图像 1,1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: 步骤 4 中的图像 1,2 Nintendo Wii Remote Front Cover Plate and Batteries Replacement: 步骤 4 中的图像 2,2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Mine is not opening like a book? What do I do?
    Micah Thompson - 回复
    It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
    Sticky Insides - 回复
结论
43等其他人完成本指南。
Emily
于04/14/13注册
1,782 声望
创作了6篇指南
团队
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G44
4 名成员
创作了28篇指南
4条评论
Worked! Had to solder the tab to contact the battery which had broken. Saved $50.00.
Graham Poor - 回复
The Tools section lists a Tri-Point Y1 Screwdriver but the guide mentions a Tri-Wing Y1 Screwdriver. This could cause people to purchase the wrong item.
iFixit’s guides seem to be based on the original Wii controller, model RVL-003. I’m not sure if Nintendo has changed fasteners for subsequent versions but the Wii MotionPlus Controller, model RVL-036, uses a Tri-Wing Y0 screw.
kivrin - 回复
@kivrin Thanks for your comment. I’m pretty sure it should say tri-point, not tri-wing. I’ll update the instructions. Tri-wing screws have a more twisted/triangular form factor, like this.
Jeff Suovanen -
My controller (the original) had three tri-wing screws and one philips. Not sure why. Had to re-solder the negative battery terminal as it came off the bottom of the ‘top’ (faces bottom) of the board.
audvare - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 126
过去 30 天: 450
总计 111,795
