简介
Disassembling the case requires removing screws under the batteries. Removing anything inside requires this guide.
你所需要的
Flip the Wii Remote over so the battery cover faces you.
Push up on the bottom tab.
Remove the battery cover.
With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
Open the front plate like a book.
Mine is not opening like a book? What do I do?
It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
36等其他人完成本指南。
4条评论
Worked! Had to solder the tab to contact the battery which had broken. Saved $50.00.
The Tools section lists a Tri-Point Y1 Screwdriver but the guide mentions a Tri-Wing Y1 Screwdriver. This could cause people to purchase the wrong item.
iFixit’s guides seem to be based on the original Wii controller, model RVL-003. I’m not sure if Nintendo has changed fasteners for subsequent versions but the Wii MotionPlus Controller, model RVL-036, uses a Tri-Wing Y0 screw.
