跳转到主内容
Nintendo Wii Heat Sink Replacement
你所需要的
  1. Nintendo Wii Heat Sink Replacement, Faceplate: 步骤 1 中的图像 1,2 Nintendo Wii Heat Sink Replacement, Faceplate: 步骤 1 中的图像 2,2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Heat Sink Replacement: 步骤 2 中的图像 1,1
    • Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
  3. Nintendo Wii Heat Sink Replacement: 步骤 3 中的图像 1,1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Heat Sink Replacement: 步骤 4 中的图像 1,1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Heat Sink Replacement: 步骤 5 中的图像 1,1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Heat Sink Replacement: 步骤 6 中的图像 1,2 Nintendo Wii Heat Sink Replacement: 步骤 6 中的图像 2,2
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Heat Sink Replacement, Outer Case: 步骤 7 中的图像 1,3 Nintendo Wii Heat Sink Replacement, Outer Case: 步骤 7 中的图像 2,3 Nintendo Wii Heat Sink Replacement, Outer Case: 步骤 7 中的图像 3,3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Heat Sink Replacement: 步骤 8 中的图像 1,2 Nintendo Wii Heat Sink Replacement: 步骤 8 中的图像 2,2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Heat Sink Replacement: 步骤 9 中的图像 1,1
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Heat Sink Replacement: 步骤 10 中的图像 1,1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Heat Sink Replacement: 步骤 11 中的图像 1,1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Wing screw
  12. Nintendo Wii Heat Sink Replacement: 步骤 12 中的图像 1,1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Heat Sink Replacement: 步骤 13 中的图像 1,1
    • Remove the two 8.2 mm Tri-Wing screws hidden under the feet you just removed.
    • You may use a 4 mm hex driver to extend your bit into the recesses and reach the screws.
  14. Nintendo Wii Heat Sink Replacement: 步骤 14 中的图像 1,1
    • Lift the outer case straight up off the body of the Wii.
  15. Nintendo Wii Heat Sink Replacement, DVD Drive: 步骤 15 中的图像 1,2 Nintendo Wii Heat Sink Replacement, DVD Drive: 步骤 15 中的图像 2,2
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • The system time will be reset once you remove the battery door.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
  16. Nintendo Wii Heat Sink Replacement: 步骤 16 中的图像 1,1
    • Remove the 8.2 mm Tri-Wing screw that was hidden beneath the battery door.
  17. Nintendo Wii Heat Sink Replacement: 步骤 17 中的图像 1,1
    • Remove the two 8.2 mm Tri-Wing screws securing the DVD drive shield near the controller ports.
  18. Nintendo Wii Heat Sink Replacement: 步骤 18 中的图像 1,1
    • Lift the DVD drive shield upward and remove it from the Wii.
  19. Nintendo Wii Heat Sink Replacement: 步骤 19 中的图像 1,1
    • Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
  20. Nintendo Wii Heat Sink Replacement: 步骤 20 中的图像 1,1
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
  21. Nintendo Wii Heat Sink Replacement: 步骤 21 中的图像 1,1
    • Pull the DVD drive power cable away from its socket on the DVD drive.
  22. Nintendo Wii Heat Sink Replacement: 步骤 22 中的图像 1,2 Nintendo Wii Heat Sink Replacement: 步骤 22 中的图像 2,2
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
  23. Nintendo Wii Heat Sink Replacement, Motherboard Cover: 步骤 23 中的图像 1,1
    • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
    • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
  24. Nintendo Wii Heat Sink Replacement: 步骤 24 中的图像 1,2 Nintendo Wii Heat Sink Replacement: 步骤 24 中的图像 2,2
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
    • Remove the fan from the Wii.
  25. Nintendo Wii Heat Sink Replacement: 步骤 25 中的图像 1,2 Nintendo Wii Heat Sink Replacement: 步骤 25 中的图像 2,2
    • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
    • Lift the Wi-Fi antenna out of the fan shroud.
  26. Nintendo Wii Heat Sink Replacement: 步骤 26 中的图像 1,1
    • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
  27. Nintendo Wii Heat Sink Replacement: 步骤 27 中的图像 1,1
    • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
  28. Nintendo Wii Heat Sink Replacement: 步骤 28 中的图像 1,1
    • Carefully de-route both antennas from the frame of the Wii and lay them aside.
  29. Nintendo Wii Heat Sink Replacement: 步骤 29 中的图像 1,2 Nintendo Wii Heat Sink Replacement: 步骤 29 中的图像 2,2
    • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
    • Lift the fan shroud off the heat sink and remove it from the Wii.
  30. Nintendo Wii Heat Sink Replacement: 步骤 30 中的图像 1,3 Nintendo Wii Heat Sink Replacement: 步骤 30 中的图像 2,3 Nintendo Wii Heat Sink Replacement: 步骤 30 中的图像 3,3
    • Remove the following six screws securing the EMI fingers to the bottom panel:
    • Four 7 mm Phillips screws
    • Two 11.3 mm Phillips screws
    • Remove both sets of EMI fingers from the Wii.
  31. Nintendo Wii Heat Sink Replacement: 步骤 31 中的图像 1,2 Nintendo Wii Heat Sink Replacement: 步骤 31 中的图像 2,2
    • Remove the following three screws:
    • One 7 mm Phillips screw
    • Two 10 mm Phillips screws
    • Lift the bracket out of the Wii.
  32. Nintendo Wii Heat Sink Replacement: 步骤 32 中的图像 1,3 Nintendo Wii Heat Sink Replacement: 步骤 32 中的图像 2,3 Nintendo Wii Heat Sink Replacement: 步骤 32 中的图像 3,3
    • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
    • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
    • Remove the bracket from the Wii.
    • Be sure not to lose the small square nut loosely held by the black plastic bracket.
  33. Nintendo Wii Heat Sink Replacement: 步骤 33 中的图像 1,1
    • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
  34. Nintendo Wii Heat Sink Replacement: 步骤 34 中的图像 1,1
    • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
    • On some models, a thermal pad for the wireless chip is attached to the underside of the motherboard cover. Be sure to replace it when reassembling.
  35. Nintendo Wii Heat Sink Replacement, Heat Sink: 步骤 35 中的图像 1,1
    • Remove the four 11.3 mm Phillips screws securing the heat sink to the bottom panel.
  36. Nintendo Wii Heat Sink Replacement: 步骤 36 中的图像 1,1
    • Lift the heat sink off the motherboard.
    • When working near the exposed processors, be sure not to disturb the thermal pads if you don't plan to replace them. They are fragile and can tear easily. If you do plan to replace the thermal pads, thermal paste can be used.
结论
17等其他人完成本指南。
9条评论
This guide also works great as a thermal paste replacement guide for the Wii, just remove the old thermal pads and clean off the heatsink, CPU, GPU, and WiFi board, and apply Thermal Grease to the CPU, GPU, And WiFi board.
Lucas Hoekstra (Lucas9810) - 回复
Worked great! Was able to reapply thermal paste on my wii. It’s working great so far!
chris morales - 回复
Can we use Thermal Paste instead of Thermal Pads?
Manuel E. Carballo Jr. - 回复
Yes, thermal paste can be used. I strongly recommend Thermal Grizzly Kryonaut, as it’s the second-best-performing non-metallic thermal paste on the market (the only better performer is Kryonaut Extreme).
Ethan Zuo -
I just finished this guide, and replaced with Noctua NT-H1 thermal paste. I needed a good amount, but I had a 10g tube and used hardly any of it. Maybe 4 or 5 desktop cpu applications worth. I let it run for while and it definitely seems like a lot more heat is venting out now compared to before, though I did clean everything as well. But there is no way its somehow worse than the gross pads that were on there.
Evan Miner -
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 66
过去 30 天: 341
总计 22,209
