跳转到主内容
Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement
你所需要的
  1. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Batteries: 步骤 1 中的图像 1,2 Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Batteries: 步骤 1 中的图像 2,2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: 步骤 2 中的图像 1,1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Front Panel: 步骤 3 中的图像 1,2 Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Front Panel: 步骤 3 中的图像 2,2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: 步骤 4 中的图像 1,2 Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: 步骤 4 中的图像 2,2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  5. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Buttons: 步骤 5 中的图像 1,3 Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Buttons: 步骤 5 中的图像 2,3 Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Buttons: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  6. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Motherboard: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers remove the three grey button pads from the motherboard.
  7. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: 步骤 7 中的图像 1,1
    • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
    • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
  8. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Shoulder Buttons: 步骤 8 中的图像 1,3 Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Shoulder Buttons: 步骤 8 中的图像 2,3 Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement, Shoulder Buttons: 步骤 8 中的图像 3,3
    • Remove the four 9-mm Phillips head screws with the Phillips #1 screwdriver.
    • Lift off the black plastic covers that secure the shoulder buttons.
  9. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: 步骤 9 中的图像 1,3 Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: 步骤 9 中的图像 2,3 Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Using the screwdriver, carefully unlock the spring clip from its holder.
    • Once unlocked, use tweezers to pull springs out of its holster.
    • The springs will try to jump out. Be careful not to lose them when setting them aside.
    • When reattaching the clips, use tweezers to align the clip with its holder and press in until it clicks.
  10. Nintendo WaveBird Wireless Controller Shoulder Buttons Replacement: 步骤 10 中的图像 1,1
    • Once the spring is removed, take out the shoulder buttons by pulling down and out.
结论
5等其他人完成本指南。
Travis Taylor
于04/12/13注册
521 声望
创作了5篇指南
团队
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G40
4 名成员
创作了37篇指南
1指南评论
Where can I buy replacement shoulder buttons? Mine are starting to get sticky and don't spring back as well as they used to. I've been looking but I can't seem to find them anywhere.
Lucas Brownlee - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 34
总计 3,538
