跳转到主内容
Nintendo WaveBird Wireless Controller Joystick Replacement
你所需要的
  1. Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: 步骤 1 中的图像 1,2 Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: 步骤 1 中的图像 2,2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Joystick Replacement: 步骤 2 中的图像 1,1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: 步骤 3 中的图像 1,2 Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: 步骤 3 中的图像 2,2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Joystick Replacement: 步骤 4 中的图像 1,2 Nintendo WaveBird Wireless Controller Joystick Replacement: 步骤 4 中的图像 2,2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  5. Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: 步骤 5 中的图像 1,3 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: 步骤 5 中的图像 2,3 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  6. Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: 步骤 6 中的图像 1,2 Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: 步骤 6 中的图像 2,2
    • Grab the base of the grey joystick cover with one hand and firmly hold down the rest of the controller with the other hand.
    • Pull off the grey joystick cover.
    • During reassembly, make sure the slots inside the joystick cover line up with the motherboard so it can fit back together.
结论
7等其他人完成本指南。
Garrett Leung
于04/16/13注册
955 声望
创作了8篇指南
团队
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G40
4 名成员
创作了37篇指南
一条评论
Question. My wavebird joystick wobbles a lot and gets stuck in directions I’m not inputting. Will replacing the top of the stick fix this? Or would I have to solder a new analog stick to the board?
Golgamang - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 79
总计 9,668
