跳转到主内容
Nintendo Switch OLED Model Dock Baseplate Replacement
你所需要的
  1. Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the rear cover: 步骤 1 中的图像 1,3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the rear cover: 步骤 1 中的图像 2,3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the rear cover: 步骤 1 中的图像 3,3
    • Use your fingers to pull the rear cover away from the frame and release its plastic clips.
    • Remove the rear cover.
  2. Nintendo Switch OLED Model Dock Baseplate Replacement, Unfasten the baseplate: 步骤 2 中的图像 1,2 Nintendo Switch OLED Model Dock Baseplate Replacement, Unfasten the baseplate: 步骤 2 中的图像 2,2
    • Use a Y0 screwdriver to unfasten the 7.5 mm-long screw securing the baseplate to the frame.
  3. Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the screw cover: 步骤 3 中的图像 1,3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the screw cover: 步骤 3 中的图像 2,3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the screw cover: 步骤 3 中的图像 3,3
    • Insert an opening tool between the frame and the plastic screw cover at the bottom-left corner.
    • Pry up with the opening tool to separate the screw cover from the frame.
    • Remove the screw cover.
  4. Nintendo Switch OLED Model Dock Baseplate Replacement, Unfasten the midframe: 步骤 4 中的图像 1,2 Nintendo Switch OLED Model Dock Baseplate Replacement, Unfasten the midframe: 步骤 4 中的图像 2,2
    • Use a Y0 screwdriver to remove the seven screws securing the midframe to the frame:
    • Four 3.9 mm screws
    • Three 7.5 mm screws
    • One 3.9 mm screw
  5. Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the midframe: 步骤 5 中的图像 1,3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the midframe: 步骤 5 中的图像 2,3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the midframe: 步骤 5 中的图像 3,3
    • Use your fingers to remove the midframe from the frame.
  6. Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the baseplate: 步骤 6 中的图像 1,3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the baseplate: 步骤 6 中的图像 2,3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the baseplate: 步骤 6 中的图像 3,3
    • Use your fingers to pull the baseplate away from the frame and release it from its plastic clips.
    • Remove the baseplate.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
Alex Diaz-Kokaisl
于01/16/22注册
214,548 声望
创作了1,044篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,764篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 82
总计 2,958
