跳转到主内容
加入维修社区 - 创建账户
Nintendo GameCube Fan replacement for cleaning
你所需要的
    1. Nintendo GameCube Fan replacement for cleaning, Top Case: 步骤 1 中的图像 1,3 Nintendo GameCube Fan replacement for cleaning, Top Case: 步骤 1 中的图像 2,3 Nintendo GameCube Fan replacement for cleaning, Top Case: 步骤 1 中的图像 3,3
      • Turn over the Gamecube so that the bottom side is facing up.
      • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
      询问修复机器人
      添加评论
    2. Nintendo GameCube Fan replacement for cleaning: 步骤 2 中的图像 1,3 Nintendo GameCube Fan replacement for cleaning: 步骤 2 中的图像 2,3 Nintendo GameCube Fan replacement for cleaning: 步骤 2 中的图像 3,3
      • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
      • Move the GameCube so that the inside is facing upwards.
      添加评论
    1. Nintendo GameCube Fan replacement for cleaning, Fan: 步骤 3 中的图像 1,2 Nintendo GameCube Fan replacement for cleaning, Fan: 步骤 3 中的图像 2,2
      • Using a Phillips #2 screwdriver, remove the two screws (circled in red) attaching the fan assembly to the unit.
      • Carefully disconnect the fan connector from the socket, as depicted in the second picture.
      • The controller connector panel can be gently pulled out of the main unit and laid down, as depicted. This is not strictly required, but may provide more maneuverability inside the case.
      • Make sure to not pull out the wires while removing the fan. Doing so may damage the connector wire or the PCB.
      询问修复机器人
      添加评论
    2. Nintendo GameCube Fan replacement for cleaning: 步骤 4 中的图像 1,2 Nintendo GameCube Fan replacement for cleaning: 步骤 4 中的图像 2,2
      • Once the fan is removed, use compressed air to clean the dust off of the fan blades.
      • It is highly recommended that you use a toothpick to prevent the fan blades from moving while cleaning. This will prevent accidental damage to the fans motor.
      添加评论
结论
取消:我没有完成这个指南。
14等其他人完成本指南。
dcarlin
于11/05/09注册
399 声望
创作了4篇指南
团队
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G2
4 名成员
创作了88篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 59
过去 30 天: 192
总计 42,834
