跳转到主内容
Nintendo GameCube Controller Joystick Replacement
你所需要的
  1. Nintendo GameCube Controller Joystick Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Joystick Replacement: 步骤 2 中的图像 1,1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Joystick Replacement, Z Button: 步骤 3 中的图像 1,2 Nintendo GameCube Controller Joystick Replacement, Z Button: 步骤 3 中的图像 2,2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller Joystick Replacement, Circuit Board: 步骤 4 中的图像 1,1
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller Joystick Replacement: 步骤 5 中的图像 1,1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Joystick Replacement, Joystick: 步骤 6 中的图像 1,2 Nintendo GameCube Controller Joystick Replacement, Joystick: 步骤 6 中的图像 2,2
    • Grab the base of the grey cover and pull it off.
    • During reassembly, make sure the slots inside the joy stick line up so they can fit back together.
结论
31等其他人完成本指南。
Sean Michel
于01/14/13注册
2,600 声望
创作了8篇指南
团队
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G44
4 名成员
创作了32篇指南
13指南评论
Great guide, but I'm looking to buy replacement joysticks and I can't find them anywhere. Where would I find those?
Joe Freedman - 回复
When I removed the joystick it would come off. The plastic was stuck too hard to the joystick so I accidentally broke it in half. Is there anyway to glue it back together?
Mattias Wirsenius - 回复
@Tyler Lovejoy - That's already part of the controller.
@Joe Freedman - Try Amazon.com
@Mattias Wirsenius - At this point it would be best to buy a new controller.
builderman1q2w3e4r - 回复
This guide is quite unhelpful; it tells you how to remove the stick but not how to repair it. My controller's joystick has sunken into the controller and stays slightly tilted if i move it to the right. Yet when I go to the "rogue joystick" portion of the troubleshooting guide, it tells me to repair the joystick if it's not correctly attached to the motherboard. Seriously, there needs to be a more in-depth guide if such repairs are possible.
J DC - 回复
without taking the controller completely apart, pull the joystick straight up with your hand
McRedstoneYT -
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 93
过去 30 天: 415
总计 106,294
