跳转到主内容
Nintendo DSi XL Speakers Replacement
你所需要的
  1. Nintendo DSi XL Speakers Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo DSi XL Speakers Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Speakers Replacement: 步骤 2 中的图像 1,1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Speakers Replacement, Rear Bezel: 步骤 3 中的图像 1,3 Nintendo DSi XL Speakers Replacement, Rear Bezel: 步骤 3 中的图像 2,3 Nintendo DSi XL Speakers Replacement, Rear Bezel: 步骤 3 中的图像 3,3
    • Use a push pin to remove the four plastic screw covers on the front bezel.
  4. Nintendo DSi XL Speakers Replacement: 步骤 4 中的图像 1,1
    • Remove four Phillips screws securing the front bezel to the rear bezel.
  5. Nintendo DSi XL Speakers Replacement: 步骤 5 中的图像 1,2 Nintendo DSi XL Speakers Replacement: 步骤 5 中的图像 2,2
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  6. Nintendo DSi XL Speakers Replacement: 步骤 6 中的图像 1,2 Nintendo DSi XL Speakers Replacement: 步骤 6 中的图像 2,2
    • Insert a spudger into the gap between the front and rear bezel
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  7. Nintendo DSi XL Speakers Replacement: 步骤 7 中的图像 1,1
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  8. Nintendo DSi XL Speakers Replacement: 步骤 8 中的图像 1,1
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  9. Nintendo DSi XL Speakers Replacement: 步骤 9 中的图像 1,1
    • Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Remove the rear bezel.
  10. Nintendo DSi XL Speakers Replacement, Speakers: 步骤 10 中的图像 1,1
    • Use a spudger to lift the antenna from the front bezel to make room for lifting the speaker cables up.
  11. Nintendo DSi XL Speakers Replacement: 步骤 11 中的图像 1,1
    • Use a spudger to lift the right speaker from its housing in the front bezel.
  12. Nintendo DSi XL Speakers Replacement: 步骤 12 中的图像 1,1
    • Use a spudger to lift the left speaker from its housing in the front bezel.
  13. Nintendo DSi XL Speakers Replacement: 步骤 13 中的图像 1,2 Nintendo DSi XL Speakers Replacement: 步骤 13 中的图像 2,2
    • De-route the left speaker cable along the top edge of the upper LCD.
  14. Nintendo DSi XL Speakers Replacement: 步骤 14 中的图像 1,1
    • Open the display slightly, and lift the LCD out of the front bezel.
    • Lay the LCD down next to the DSi XL.
    • Don't attempt to remove the LCD, it is still attached to the front bezel via the display data ribbon cable.
  15. Nintendo DSi XL Speakers Replacement: 步骤 15 中的图像 1,1
    • Desolder the two solder joints to separate the speakers from the LCD.
    • Right Speaker
    • Left Speaker
    • For both speakers, the red wire (positive lead) is soldered to the left contact. The black wire (negative lead) is soldered to the right contact point.
    • For detailed instructions on how to solder this type of connection, see our guide for repairing soldered connections.
结论
3等其他人完成本指南。
Matthew Newsom
于01/05/10注册
40,929 声望
创作了67篇指南
3指南评论
Thank you for this video but I need some more help cause I dont know if my problem are the speakers or the earphones jack how can I solve this just one clue i need thanks again
Josh - 回复
In my case, it turned out there was nothing wrong with my speaker… one of the wires that feeds around the screen was bad.
Dave Horlick - 回复
is there anyway of adding two more speaker?
vincent johnson - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 42
总计 7,124
