当前版本的文档还未经巡查,您可以查看最新的已查核版本。
简介
更换你的Nintendo DS Lite扬声器,让你的游戏再次发声!
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Position the antenna cable with its connector facing up and away from the motherboard using a spudger to hold it down lightly in the gap between chips on the motherboard.
Slowly and carefully pull the antenna cable until the cable connector is under the DS Lite game cartridge reader.
Continue pulling the cable until the cable connector comes out from under the game cartridge reader on the right side.
这个步骤还没有翻译 帮忙翻译一下
Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap.
Pull the motherboard away from the DS Lite to separate the upper LCD ribbon cable from its socket on the motherboard.
Remove the motherboard from the DS Lite.
Now you may open the retaining flap for the lower LCD screen in the same way and separate the lower LCD screen from the motherboard.
按照指南的倒序重新组装好你的设备。
按照指南的倒序重新组装好你的设备。
15等其他人完成本指南。
由衷感谢以下译者:
100%
Cinmu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
3条评论
what is the temperature for soldering the speakers off and inserting it back in?
Wouldn’t be easier to just get to the speakers, desolder the wires at the speaker and resolder new ones in?
Wouldn’t it be easier just to get to the speakers, unsolder the wires at the speakers, and resoldered new ones in?
