跳转到主内容
Nintendo 3DS XL Top and Bottom Outer Casing Replacement
你所需要的
  1. Nintendo 3DS XL Top and Bottom Outer Casing Replacement, Top and Bottom Outer Casing: 步骤 1 中的图像 1,2 Nintendo 3DS XL Top and Bottom Outer Casing Replacement, Top and Bottom Outer Casing: 步骤 1 中的图像 2,2
    • Ensure that the system is turned OFF.
    • Place the device on a hard surface with the rear panel facing you.
    • Unscrew the two 2.0 mm screws in a counterclockwise motion using a Phillips #00 screwdriver.
    • A "click" sound will be made after each successful unscrewing.
  2. Nintendo 3DS XL Top and Bottom Outer Casing Replacement: 步骤 2 中的图像 1,3 Nintendo 3DS XL Top and Bottom Outer Casing Replacement: 步骤 2 中的图像 2,3 Nintendo 3DS XL Top and Bottom Outer Casing Replacement: 步骤 2 中的图像 3,3
    • Pry open the wedges of the rear case by using a pick.
    • Unhinge the corners with a pick if the case is not coming loose easily.
    • Detach the rear case by pulling it away from the device.
  3. Nintendo 3DS XL Top and Bottom Outer Casing Replacement: 步骤 3 中的图像 1,2 Nintendo 3DS XL Top and Bottom Outer Casing Replacement: 步骤 3 中的图像 2,2
    • Make sure the battery is in its seated position.
    • Place the replacement rear case onto the rear panel of device.
    • Snap the new case in place by pressing its wedges onto the rear panels.
    • A click sound will indicate successful locking of the wedges.
    • Screw in a clockwise motion the 2.0 mm screws using the Phillips #00 screwdriver.
  4. Nintendo 3DS XL Top and Bottom Outer Casing Replacement: 步骤 4 中的图像 1,3 Nintendo 3DS XL Top and Bottom Outer Casing Replacement: 步骤 4 中的图像 2,3 Nintendo 3DS XL Top and Bottom Outer Casing Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Flip the device over to its top side and open its lid.
    • Be careful when using the tools close to the screen.
    • Remove the rubber pieces with the help of tweezers.
    • Unscrew the 2.0 mm screws in a counterclockwise motion with a Phillips #00 screwdriver.
  5. Nintendo 3DS XL Top and Bottom Outer Casing Replacement: 步骤 5 中的图像 1,2 Nintendo 3DS XL Top and Bottom Outer Casing Replacement: 步骤 5 中的图像 2,2
    • From the hinge, slide the outer portion of the top shell so that it separates from the inner portion.
    • This step was edited recently because the previous version was risky. It told people to use a spudger and slide it around the edges. DO NOT DO THIS!!! It will snap tabs off!
    • The casing will become loose, and just lift the casing off.
  6. Nintendo 3DS XL Top and Bottom Outer Casing Replacement: 步骤 6 中的图像 1,1
    • If your replacement case comes with its own camera lens, this step does not apply to you and you may proceed to the next step.
    • Pull the camera lens from the original case with the help of tweezers.
    • Slot the camera lens into the new case.
    • Repeat the steps above for the second camera lens.
  7. Nintendo 3DS XL Top and Bottom Outer Casing Replacement: 步骤 7 中的图像 1,1
    • Reassemble the top case with the replacement piece by following instructions in reverse.
结论
It is important to exercise caution while reassembling the device to prevent damage to the LCD screen and screws. Therefore, make sure not to overtighten the top case screws during the reassembly process.
4等其他人完成本指南。
一条评论
This is wrong for the top cover. You have to slide it out and be careful with how two little locks slot back in on the back side.
https://youtu.be/lQ1qtj5N1p0?si=Pkeq6PoT...
ravenrue - 回复
添加评论
浏览统计数据:
过去 24 小时: 30
过去 7 天: 209
过去 30 天: 941
总计 7,735
