跳转到主内容
Nintendo 3DS Upper Display Assembly Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Nintendo 3DS Upper Display Assembly Replacement, Upper Display Assembly: 步骤 1 中的图像 1,1
    • Remove the 3D adjustment switch from the front display bezel.
    • This step is not necessary for disassembly, but the switch is likely to fall out on its own. By removing it yourself, you reduce the chance of losing it.
  2. Nintendo 3DS Upper Display Assembly Replacement: 步骤 2 中的图像 1,3 Nintendo 3DS Upper Display Assembly Replacement: 步骤 2 中的图像 2,3 Nintendo 3DS Upper Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Insert a metal probe into the space above the ABXY buttons with the point touching the metal hinge.
    • Push the hinge towards the center of the upper case. This will require a fair amount of force.
    • Before and after images of the hinge location when looking at the back of the upper display are shown.
  3. Nintendo 3DS Upper Display Assembly Replacement: 步骤 3 中的图像 1,3 Nintendo 3DS Upper Display Assembly Replacement: 步骤 3 中的图像 2,3 Nintendo 3DS Upper Display Assembly Replacement: 步骤 3 中的图像 3,3
    • Before proceeding, note how the 3 ribbon cables are oriented (what direction the gold contacts face) and layered together (which cable is on top of which). The cables are too short to reach if they are threaded through in any other orientation.
    • Slowly pull the upper display assembly away from the upper case.
    • Make sure that the various ribbon cables are being fed through the slit in the upper case.
    • Separate the upper display assembly from the upper case.
结论
David Hodson
于04/13/10注册
154,761 声望
创作了127篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 311
