当前版本的文档还未经巡查,您可以查看最新的已查核版本。
将塑料拆机工具插入位于电池与电池仓之间的凹槽中。
用塑料拆机工具撬起电池。
抓住电池的顶部边缘,将其从电池仓中抬起。
Remove the nine 6.3 mm black Phillips screws from the lower case.
These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Lift the bottom edge of the lower case off the rest of the 3DS.
There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
Remove the lower case from the device.
Remove the four 2.4 mm Phillips screws that secure the stylus housing to the lower case.
Use a plastic opening tool to pry the stylus housing up from the lower case.
Grab the stylus housing and remove it from the lower case.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
