跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Nintendo 3DS Motherboard Assembly Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: 步骤 1 中的图像 1,2 Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: 步骤 1 中的图像 2,2
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  2. Nintendo 3DS Motherboard Assembly Replacement: 步骤 2 中的图像 1,3 Nintendo 3DS Motherboard Assembly Replacement: 步骤 2 中的图像 2,3 Nintendo 3DS Motherboard Assembly Replacement: 步骤 2 中的图像 3,3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
  3. Nintendo 3DS Motherboard Assembly Replacement: 步骤 3 中的图像 1,2 Nintendo 3DS Motherboard Assembly Replacement: 步骤 3 中的图像 2,2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
  4. Nintendo 3DS Motherboard Assembly Replacement: 步骤 4 中的图像 1,3 Nintendo 3DS Motherboard Assembly Replacement: 步骤 4 中的图像 2,3 Nintendo 3DS Motherboard Assembly Replacement: 步骤 4 中的图像 3,3
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
  5. Nintendo 3DS Motherboard Assembly Replacement: 步骤 5 中的图像 1,3 Nintendo 3DS Motherboard Assembly Replacement: 步骤 5 中的图像 2,3 Nintendo 3DS Motherboard Assembly Replacement: 步骤 5 中的图像 3,3
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
  6. Nintendo 3DS Motherboard Assembly Replacement: 步骤 6 中的图像 1,1
    • Remove the motherboard assembly from the rest of the device.
结论
David Hodson
于04/13/10注册
150,580 声望
创作了127篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 1,591
