跳转到主内容
Nintendo 3DS Lower Case Replacement
你所需要的
  1. Nintendo 3DS Lower Case Replacement, Loosen the rear screws: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
  2. Nintendo 3DS Lower Case Replacement, Remove the rear cover: 步骤 2 中的图像 1,2 Nintendo 3DS Lower Case Replacement, Remove the rear cover: 步骤 2 中的图像 2,2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Lower Case Replacement, Battery: 步骤 3 中的图像 1,3 Nintendo 3DS Lower Case Replacement, Battery: 步骤 3 中的图像 2,3 Nintendo 3DS Lower Case Replacement, Battery: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Lower Case Replacement, Lower Case: 步骤 4 中的图像 1,1
    • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is desinged to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
    • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
  5. Nintendo 3DS Lower Case Replacement: 步骤 5 中的图像 1,3 Nintendo 3DS Lower Case Replacement: 步骤 5 中的图像 2,3 Nintendo 3DS Lower Case Replacement: 步骤 5 中的图像 3,3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
结论
8等其他人完成本指南。
David Hodson
于04/13/10注册
154,628 声望
创作了127篇指南
3指南评论
Is this guide for the original 3ds?
Glenn Racz - 回复
yessir it is
Electronik -
havent tried it (was thinking of shell swapping to see how hard it is) but it seems kinda easy for moderate rating you just remove 14 screws sorry if im wrong
MyComputerMinecraft - 回复
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 82
过去 30 天: 418
总计 19,524
