跳转到主内容
Nintendo 3DS Circle Pad Joystick Replacement
你所需要的
  1. Nintendo 3DS Circle Pad Joystick Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Circle Pad Joystick Replacement: 步骤 2 中的图像 1,2 Nintendo 3DS Circle Pad Joystick Replacement: 步骤 2 中的图像 2,2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Circle Pad Joystick Replacement, Battery: 步骤 3 中的图像 1,3 Nintendo 3DS Circle Pad Joystick Replacement, Battery: 步骤 3 中的图像 2,3 Nintendo 3DS Circle Pad Joystick Replacement, Battery: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Circle Pad Joystick Replacement, Lower Case: 步骤 4 中的图像 1,1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. Nintendo 3DS Circle Pad Joystick Replacement: 步骤 5 中的图像 1,3 Nintendo 3DS Circle Pad Joystick Replacement: 步骤 5 中的图像 2,3 Nintendo 3DS Circle Pad Joystick Replacement: 步骤 5 中的图像 3,3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS Circle Pad Joystick Replacement, Circle Pad Joystick: 步骤 6 中的图像 1,1
    • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
  7. Nintendo 3DS Circle Pad Joystick Replacement: 步骤 7 中的图像 1,3 Nintendo 3DS Circle Pad Joystick Replacement: 步骤 7 中的图像 2,3 Nintendo 3DS Circle Pad Joystick Replacement: 步骤 7 中的图像 3,3
    • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
    • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
  8. Nintendo 3DS Circle Pad Joystick Replacement: 步骤 8 中的图像 1,3 Nintendo 3DS Circle Pad Joystick Replacement: 步骤 8 中的图像 2,3 Nintendo 3DS Circle Pad Joystick Replacement: 步骤 8 中的图像 3,3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Lift the Circle Pad joystick off the motherboard.
结论
11等其他人完成本指南。
David Hodson
于04/13/10注册
150,503 声望
创作了127篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 88
过去 30 天: 427
总计 29,443
