简介
If you aren't getting full range of motion on the D pad replacing may fix it. Go slow. There are several delicate ribbons cables. Make sure that components are completely disconnected before you pull them apart.
你所需要的
Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
在这个步骤中使用的工具:Tweezers$4.99
Reorient the device so that the game slot now faces you.
Remove the two rubber bumpers along the top of the device using tweezers.
Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
Locate the gamecard reader near the bottom right corner of the motherboard.
Unscrew the four 3mm Phillips #00 screws along the edge of the gamecard reader.
Lift the black latch on the ZIF connector along the right side of the reader using a plastic opening tool.
Remove the four 3mm Phillips #00 screws from the four corners of the D pad board.
Lift the D pad board out of the device.
4指南评论
Thanks for pointing that out! I think it is fixed now.
-Tyler
