跳转到主内容
Ninja NJ600 Power Cord Replacement
你所需要的
  1. Ninja NJ600 Power Cord Replacement, Blender Base Cover: 步骤 1 中的图像 1,2 Ninja NJ600 Power Cord Replacement, Blender Base Cover: 步骤 1 中的图像 2,2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Power Cord Replacement: 步骤 2 中的图像 1,2 Ninja NJ600 Power Cord Replacement: 步骤 2 中的图像 2,2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Power Cord Replacement: 步骤 3 中的图像 1,3 Ninja NJ600 Power Cord Replacement: 步骤 3 中的图像 2,3 Ninja NJ600 Power Cord Replacement: 步骤 3 中的图像 3,3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Power Cord Replacement, Power Cord: 步骤 4 中的图像 1,1
    • Remove these two screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
  5. Ninja NJ600 Power Cord Replacement: 步骤 5 中的图像 1,1
    • Your blender and power cord should look like this now that the two screws have been removed.
    • In the next steps we will highlight two issues that your power cord may have.
  6. Ninja NJ600 Power Cord Replacement: 步骤 6 中的图像 1,1
    • Your power cord is soldered to the circuit board as shown.
    • A loose or damaged connection could explain why your blender is not turning on.
    • Desolder the connection using the iFixit guide that describes this process.
    • Solder the wires back on to the circuit board. Refer to the iFixit soldering guide for assistance.
    • Soldering iron is very hot, use caution when handling
  7. Ninja NJ600 Power Cord Replacement: 步骤 7 中的图像 1,2 Ninja NJ600 Power Cord Replacement: 步骤 7 中的图像 2,2
    • If there were no issues with the soldering connection in Step 6, check the wiring in the picture shown.
    • Remove the zip ties with a pair of scissors. Then remove the plastic that covers the wires.
    • If the wires underneath the plastic covers are loose or disconnected, try to desolder and solder the wires. Use the iFixit soldering guide to assist in this step.
结论
Trevor Waite
于04/01/15注册
275 声望
撰写一个指南
团队
Cal Poly, Team 24-2, Lancaster Spring 2015 Cal Poly, Team 24-2, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 13
总计 2,951
