跳转到主内容
Ninja NJ600 Circuit Board Replacement
你所需要的
  1. Ninja NJ600 Circuit Board Replacement, Blender Base Cover: 步骤 1 中的图像 1,2 Ninja NJ600 Circuit Board Replacement, Blender Base Cover: 步骤 1 中的图像 2,2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Circuit Board Replacement: 步骤 2 中的图像 1,2 Ninja NJ600 Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Circuit Board Replacement: 步骤 3 中的图像 1,3 Ninja NJ600 Circuit Board Replacement: 步骤 3 中的图像 2,3 Ninja NJ600 Circuit Board Replacement: 步骤 3 中的图像 3,3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Circuit Board Replacement, Circuit Board: 步骤 4 中的图像 1,1
    • Remove these four screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
    • Be careful not to scratch the circuit board with the screwdriver.
  5. Ninja NJ600 Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Using a pair of scissors or wire cutters, cut the zip tie holding these wires.
    • This will give the circuit board more range of motion.
  6. Ninja NJ600 Circuit Board Replacement: 步骤 6 中的图像 1,3 Ninja NJ600 Circuit Board Replacement: 步骤 6 中的图像 2,3 Ninja NJ600 Circuit Board Replacement: 步骤 6 中的图像 3,3
    • Desolder the five wires from the solder pads shown.
    • If you do not know how to do this, iFixit has a guide describing the process.
    • Before you begin to desolder these wires, flip the board over to confirm that you are about to desolder the correct component.
    • Soldering iron is very hot, use caution when handling
  7. Ninja NJ600 Circuit Board Replacement: 步骤 7 中的图像 1,1
    • After the wires have cooled enough to touch, carefully slide the circuit board free of the wires.
    • NOTE: keep track of which pad each wire was soldered to. This is important for your blender to function.
结论
To reassemble your device, follow these instructions in reverse order, but solder the wires back to the board.
2等其他人完成本指南。
Kody D
于04/01/15注册
537 声望
创作了3篇指南
团队
Cal Poly, Team 24-2, Lancaster Spring 2015 Cal Poly, Team 24-2, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G2
4 名成员
创作了6篇指南
4条评论
Good article. How do I get hold of a board?
Odman - 回复
Where can I buy de circuito board?
carlareis1 - 回复
Where can i buy the circuit board ?
Adesoye Olatunji - 回复
Hi, where can I buy this board please?
Daniel - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 32
总计 3,407
