跳转到主内容
Ninja Mega Kitchen System BL770 Power Cord Replacement
你所需要的
  1. Ninja Mega Kitchen System BL770 Power Cord Replacement, Circuit Base: 步骤 1 中的图像 1,2 Ninja Mega Kitchen System BL770 Power Cord Replacement, Circuit Base: 步骤 1 中的图像 2,2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Power Cord Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Power Cord Replacement: 步骤 3 中的图像 1,3 Ninja Mega Kitchen System BL770 Power Cord Replacement: 步骤 3 中的图像 2,3 Ninja Mega Kitchen System BL770 Power Cord Replacement: 步骤 3 中的图像 3,3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Power Cord Replacement: 步骤 4 中的图像 1,1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Power Cord Replacement, Power Cord: 步骤 5 中的图像 1,2 Ninja Mega Kitchen System BL770 Power Cord Replacement, Power Cord: 步骤 5 中的图像 2,2
    • Check that the two red wires shown in the photos are properly soldered to the circuit board.
    • If they seem damaged, resolder the wires to the board.
    • If this doesn't solve the issue, proceed to step 6.
  6. Ninja Mega Kitchen System BL770 Power Cord Replacement: 步骤 6 中的图像 1,1
    • If the 2 wires in the previous step are connected, it's time to check the 2nd area.
    • Remove the plastic covers and check that the wires are soldered correctly.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 969
