跳转到主内容
Ninja Mega Kitchen System BL770 Circuit Board Replacement
你所需要的
  1. Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Base: 步骤 1 中的图像 1,2 Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Base: 步骤 1 中的图像 2,2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Circuit Board Replacement: 步骤 3 中的图像 1,3 Ninja Mega Kitchen System BL770 Circuit Board Replacement: 步骤 3 中的图像 2,3 Ninja Mega Kitchen System BL770 Circuit Board Replacement: 步骤 3 中的图像 3,3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Board: 步骤 5 中的图像 1,2 Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Board: 步骤 5 中的图像 2,2
    • Cautiously desolder all the wires connecting the circuit board to the unit.
    • Carefully slide the circuit board free of the wires are place the new board in.
    • Solder the wires back onto the new board, keeping track of which wire goes where in order for your unit to properly function.
结论
6等其他人完成本指南。
16指南评论
Thanks for the post… this is helping me with my blender…. by any chance do you have a better picture of the resistor on the back of the circuit board… it seems to be a yellow blue blue gold sequence resistor… my board just burned that resistor and I am trying to find and replace just that resistor if possible… but I am not sure of the colors so I can locate the right now.
Jose Gonzalez - 回复
Does somebody know where can I buy this circuit board ??
castro_73 - 回复
Anyone know the chip on this circuit board?? Proprietary I assume??
Nathan Walter - 回复
Great info but i’m looking to purchase a replacement circuit board for my ninja blender and can not find one. Any ideas?
Rich - 回复
hi,, i need to know the reference of transistor with position Q2. in the main board BL770 , thanks.
kolin camacho - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 45
过去 30 天: 202
总计 7,117
