跳转到主内容
Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement
你所需要的
  1. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement, Valve Tubes: 步骤 1 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement, Valve Tubes: 步骤 1 中的图像 2,2
    • Remove the eight 6 mm screws using the Phillips #1 screwdriver.
    • Remove the bottom cover.
  2. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement: 步骤 2 中的图像 1,1
    • Remove the three 6 mm screws with the Phillips #1 screwdriver.
    • Remove the plastic cover.
  3. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement: 步骤 3 中的图像 1,1
    • Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
  4. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement: 步骤 4 中的图像 1,1
    • Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
结论
Naser Aldousari
于10/10/17注册
310 声望
创作了3篇指南
团队
USF Tampa, Team S13-G69, Cagle Fall 2017 USF Tampa, Team S13-G69, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G69
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 898
