跳转到主内容
加入维修社区 - 创建账户
Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement
你所需要的
  1. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement, Drip Stop Toggle and Brew Basket: 步骤 1 中的图像 1,1
    • Slide the brew baskets to the open position.
    询问修复机器人
    添加评论
  2. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 2 中的图像 1,1
    • Remove three 6mm screws with Phillips head screw driver.
    询问修复机器人
    添加评论
  3. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 3 中的图像 1,3 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 3 中的图像 2,3 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Using needle nose tweezers, push the bottom of the pin up from behind the brew basket
    • Pull the pin out.
    询问修复机器人
    添加评论
  4. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 4 中的图像 1,1
    • Remove brew basket from swinging basket holder
    询问修复机器人
    添加评论
  5. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 5 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips screwdriver to remove one 6mm screw from the drip stop toggle.
    • Remove the drip stop toggle.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team S13-G69, Cagle Fall 2017 USF Tampa, Team S13-G69, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G69
4 名成员
创作了9篇指南
4指南评论
Can you provide more detail regarding the small spring that you provide the warning for? The one that needs to stay in place. If it does fall out, how can not be fixed or rather where does not go?
Dani - 回复 分享
Agree! The spring NEEDS to be resting vertically in between the two clips, in my case, these have worn and the spring came out of seat. It needed to be refastened and the five beeps, “of death” have disappeared and my coffeepot functions again!
Marcus Martinez - 回复 分享
* this works on the ninja coffee bar larger system as well
Detalles del resorte porfavor. Si se sale como colocarlo?
Geraldine Loredo - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 81
总计 8,201
