跳转到主内容
Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement
你所需要的
  1. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement, Drip Stop Toggle and Brew Basket: 步骤 1 中的图像 1,1
    • Slide the brew baskets to the open position.
  2. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 2 中的图像 1,1
    • Remove three 6mm screws with Phillips head screw driver.
  3. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 3 中的图像 1,3 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 3 中的图像 2,3 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using needle nose tweezers, push the bottom of the pin up from behind the brew basket
    • Pull the pin out.
  4. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 4 中的图像 1,1
    • Remove brew basket from swinging basket holder
  5. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 5 中的图像 1,2 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips screwdriver to remove one 6mm screw from the drip stop toggle.
    • Remove the drip stop toggle.
结论
Naser Aldousari
于10/10/17注册
310 声望
创作了3篇指南
团队
USF Tampa, Team S13-G69, Cagle Fall 2017 USF Tampa, Team S13-G69, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G69
4 名成员
创作了3篇指南
3条评论
Can you provide more detail regarding the small spring that you provide the warning for? The one that needs to stay in place. If it does fall out, how can not be fixed or rather where does not go?
Dani - 回复
Agree! The spring NEEDS to be resting vertically in between the two clips, in my case, these have worn and the spring came out of seat. It needed to be refastened and the five beeps, “of death” have disappeared and my coffeepot functions again!
Marcus Martinez - 回复
* this works on the ninja coffee bar larger system as well
Marcus Martinez -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 48
总计 6,976
