跳转到主内容
Nikon D80 Flash Assembly Replacement
你所需要的
  1. Nikon D80 Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 1,3 Nikon D80 Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 2,3 Nikon D80 Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 3,3
    • Press the highlighted button to pop the flash up.
    • Otherwise, use a plastic opening tool to gently lever open the flash by inserting the tool into the gap between the flash and the camera.
  2. Nikon D80 Flash Assembly Replacement: 步骤 2 中的图像 1,1
    • Use the #00 Phillips-head screwdriver to remove both 4.20 mm screws by rotating the screwdriver to the left.
  3. Nikon D80 Flash Assembly Replacement: 步骤 3 中的图像 1,2 Nikon D80 Flash Assembly Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, pry open the cover.
    • Be advised, some plastic struts may snap off when you remove the cover.
  4. Nikon D80 Flash Assembly Replacement: 步骤 4 中的图像 1,2 Nikon D80 Flash Assembly Replacement: 步骤 4 中的图像 2,2
    • Using a soldering iron, desolder the orange, tan, and gray wires from the flash assembly.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Use caution while using the hot soldering iron.
  5. Nikon D80 Flash Assembly Replacement: 步骤 5 中的图像 1,1
    • Gently remove the flash assembly from the casing.
    • The surface may still be hot, so grab it with caution.
结论
Kevin Horwedel
于10/09/17注册
211 声望
撰写一个指南
团队
USF Tampa, Team S1-G1, Leahy Fall 2017 USF Tampa, Team S1-G1, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G1
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 27
总计 2,595
