跳转到主内容
Nikon D7000 Tripod Plate Replacement
你所需要的
  1. Nikon D7000 Tripod Plate Replacement, Motherboard: 步骤 1 中的图像 1,1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Tripod Plate Replacement: 步骤 2 中的图像 1,1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Tripod Plate Replacement: 步骤 3 中的图像 1,2 Nikon D7000 Tripod Plate Replacement: 步骤 3 中的图像 2,2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Tripod Plate Replacement: 步骤 4 中的图像 1,1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Tripod Plate Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Tripod Plate Replacement: 步骤 6 中的图像 1,1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Tripod Plate Replacement: 步骤 7 中的图像 1,1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Tripod Plate Replacement: 步骤 8 中的图像 1,1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Tripod Plate Replacement: 步骤 9 中的图像 1,1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Tripod Plate Replacement: 步骤 10 中的图像 1,1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Tripod Plate Replacement: 步骤 11 中的图像 1,1
    • Gently pull the SD card cover off.
  12. Nikon D7000 Tripod Plate Replacement: 步骤 12 中的图像 1,1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Tripod Plate Replacement: 步骤 13 中的图像 1,1
    • Carefully lift the back case off.
  14. Nikon D7000 Tripod Plate Replacement: 步骤 14 中的图像 1,3 Nikon D7000 Tripod Plate Replacement: 步骤 14 中的图像 2,3 Nikon D7000 Tripod Plate Replacement: 步骤 14 中的图像 3,3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Tripod Plate Replacement: 步骤 15 中的图像 1,2 Nikon D7000 Tripod Plate Replacement: 步骤 15 中的图像 2,2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Tripod Plate Replacement: 步骤 16 中的图像 1,1
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Tripod Plate Replacement: 步骤 17 中的图像 1,1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Tripod Plate Replacement: 步骤 18 中的图像 1,1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Tripod Plate Replacement: 步骤 19 中的图像 1,3 Nikon D7000 Tripod Plate Replacement: 步骤 19 中的图像 2,3 Nikon D7000 Tripod Plate Replacement: 步骤 19 中的图像 3,3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Tripod Plate Replacement: 步骤 20 中的图像 1,2 Nikon D7000 Tripod Plate Replacement: 步骤 20 中的图像 2,2
  21. Nikon D7000 Tripod Plate Replacement: 步骤 21 中的图像 1,1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Tripod Plate Replacement: 步骤 22 中的图像 1,1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Tripod Plate Replacement: 步骤 23 中的图像 1,1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Tripod Plate Replacement: 步骤 24 中的图像 1,1
    • Lift the motherboard off.
  25. Nikon D7000 Tripod Plate Replacement, Tripod Plate: 步骤 25 中的图像 1,1
    • Remove four 6 mm J000 screws securing the tripod plate.
  26. Nikon D7000 Tripod Plate Replacement: 步骤 26 中的图像 1,1
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
结论
另外一个人完成了本指南。
Jed Chen
于04/01/15注册
1,796 声望
创作了3篇指南
团队
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 2,375
