跳转到主内容
Nikon D7000 Shutter Assembly Replacement
你所需要的
  1. Nikon D7000 Shutter Assembly Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Shutter Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Shutter Assembly Replacement: 步骤 3 中的图像 1,2 Nikon D7000 Shutter Assembly Replacement: 步骤 3 中的图像 2,2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Shutter Assembly Replacement: 步骤 4 中的图像 1,1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Shutter Assembly Replacement: 步骤 5 中的图像 1,1
    • Peel the rear rubber piece off with tweezers.
    This is not needed : if you don't touch this rubber & screw the SD card cover will come off at the same time that the back case.
    = Quicker and easier
    Xavier - 回复
  6. Nikon D7000 Shutter Assembly Replacement: 步骤 6 中的图像 1,1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
    Xavier - 回复
  7. Nikon D7000 Shutter Assembly Replacement: 步骤 7 中的图像 1,1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Shutter Assembly Replacement: 步骤 8 中的图像 1,1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
    Concerning the diopter, it's wrong : D7000 also have a screw in it.
    See step 41.
    Xavier - 回复
  9. Nikon D7000 Shutter Assembly Replacement: 步骤 9 中的图像 1,1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Shutter Assembly Replacement: 步骤 10 中的图像 1,1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Shutter Assembly Replacement: 步骤 11 中的图像 1,1
    • Gently pull the SD card cover off.
    Attention! High voltage. After removing the memory card cover, remove the yellow sticker and use a 220 volt 15 watt incandescent lamp to discharge the capacitor.
    Rust Twentyone - 回复
  12. Nikon D7000 Shutter Assembly Replacement: 步骤 12 中的图像 1,1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Shutter Assembly Replacement: 步骤 13 中的图像 1,1
    • Carefully lift the back case off.
  14. Nikon D7000 Shutter Assembly Replacement: 步骤 14 中的图像 1,3 Nikon D7000 Shutter Assembly Replacement: 步骤 14 中的图像 2,3 Nikon D7000 Shutter Assembly Replacement: 步骤 14 中的图像 3,3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Shutter Assembly Replacement: 步骤 15 中的图像 1,2 Nikon D7000 Shutter Assembly Replacement: 步骤 15 中的图像 2,2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Shutter Assembly Replacement: 步骤 16 中的图像 1,1
    • Gently pry and lift the left motherboard shield off.
    No need to remove shield. Risk of damaging clips holding shield.
    Ziyang - 回复
  17. Nikon D7000 Shutter Assembly Replacement: 步骤 17 中的图像 1,1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
    Ziyang - 回复
  18. Nikon D7000 Shutter Assembly Replacement: 步骤 18 中的图像 1,1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Shutter Assembly Replacement: 步骤 19 中的图像 1,3 Nikon D7000 Shutter Assembly Replacement: 步骤 19 中的图像 2,3 Nikon D7000 Shutter Assembly Replacement: 步骤 19 中的图像 3,3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Shutter Assembly Replacement: 步骤 20 中的图像 1,2 Nikon D7000 Shutter Assembly Replacement: 步骤 20 中的图像 2,2
    One more ribbon behind press down tab
    Ziyang - 回复
  21. Nikon D7000 Shutter Assembly Replacement: 步骤 21 中的图像 1,1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Shutter Assembly Replacement: 步骤 22 中的图像 1,1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Shutter Assembly Replacement: 步骤 23 中的图像 1,1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Shutter Assembly Replacement: 步骤 24 中的图像 1,1
    • Lift the motherboard off.
  25. Nikon D7000 Shutter Assembly Replacement, Tripod Plate: 步骤 25 中的图像 1,1
    • Remove four 6 mm J000 screws securing the tripod plate.
    Only left 2 screw need to be removed. The tripod plate do not need to be removed.
    Ziyang - 回复
    Actually, nothing needs to be removed !
    Skip this step and gain time and energy :)
    Xavier - 回复
  26. Nikon D7000 Shutter Assembly Replacement: 步骤 26 中的图像 1,1
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
    Skip this step (see comment step 25)
    Xavier - 回复
  27. Nikon D7000 Shutter Assembly Replacement, Image Sensor: 步骤 27 中的图像 1,2 Nikon D7000 Shutter Assembly Replacement, Image Sensor: 步骤 27 中的图像 2,2
    • Disconnect black and white speaker cable.
  28. Nikon D7000 Shutter Assembly Replacement: 步骤 28 中的图像 1,1
    • Remove three 6 mm J000 screws securing the image sensor.
    Best to set markings on the three screws before removing sensor. To preserve alignment of sensor and body frame
    Ziyang - 回复
    This step is NOT necessary if you don't plan on doing anything with the sensor itself
    -> just let it all attached together and save yourself time and energy
    Xavier - 回复
  29. Nikon D7000 Shutter Assembly Replacement: 步骤 29 中的图像 1,1
    • Carefully lift the image sensor plate out of the camera.
  30. Nikon D7000 Shutter Assembly Replacement, Shutter Assembly: 步骤 30 中的图像 1,1
    • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
    • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
  31. Nikon D7000 Shutter Assembly Replacement: 步骤 31 中的图像 1,1
    • Remove two 5 mm J000 screws from under the flash.
  32. Nikon D7000 Shutter Assembly Replacement: 步骤 32 中的图像 1,1
    • Remove two 3 mm J000 screws securing the front cover.
    These screws should be the other way around. I took the 5mm screws out of the front cover. 3mm screws from under the flash.
    Jamie MacLeod - 回复
  33. Nikon D7000 Shutter Assembly Replacement: 步骤 33 中的图像 1,2 Nikon D7000 Shutter Assembly Replacement: 步骤 33 中的图像 2,2
    • Remove the front cover.
  34. Nikon D7000 Shutter Assembly Replacement: 步骤 34 中的图像 1,1
    • Carefully remove the port cover.
  35. Nikon D7000 Shutter Assembly Replacement: 步骤 35 中的图像 1,1
    • Deroute the microphone cable.
  36. Nikon D7000 Shutter Assembly Replacement: 步骤 36 中的图像 1,1
    • Remove one 4 mm J000 screw from the front.
  37. Nikon D7000 Shutter Assembly Replacement: 步骤 37 中的图像 1,1
    • Remove one 8.5 mm J000 screw from the battery compartment.
  38. Nikon D7000 Shutter Assembly Replacement: 步骤 38 中的图像 1,1
    • Remove the grip carefully.
  39. Nikon D7000 Shutter Assembly Replacement: 步骤 39 中的图像 1,1
    • Remove one 4 mm J000 screw securing the top case (under right strap hook).
  40. Nikon D7000 Shutter Assembly Replacement: 步骤 40 中的图像 1,1
    • Remove one 4 mm J000 screw securing the top case (under left strap hook).
  41. Nikon D7000 Shutter Assembly Replacement: 步骤 41 中的图像 1,1
    • Remove the sticker covering the diopter adjust screw.
  42. Nikon D7000 Shutter Assembly Replacement: 步骤 42 中的图像 1,1
    • Remove one 8.0 mm J000 screw.
    • Remove the Diopeter Adjust.
  43. Nikon D7000 Shutter Assembly Replacement: 步骤 43 中的图像 1,1
    • Remove the top case.
    No mention of discharging the flash capacitor first?
    digimaan - 回复
    Make sure you don’t get a shock off it .
    Dean Wilkinson - 回复
  44. Nikon D7000 Shutter Assembly Replacement: 步骤 44 中的图像 1,1
    • Remove the Black, Yellow, Green cable from the top case board.
    If intend to remove top panel entirely, will need to de-solder the black and red power cable
    Ziyang - 回复
  45. Nikon D7000 Shutter Assembly Replacement: 步骤 45 中的图像 1,3 Nikon D7000 Shutter Assembly Replacement: 步骤 45 中的图像 2,3 Nikon D7000 Shutter Assembly Replacement: 步骤 45 中的图像 3,3
    • Remove two 6.5 mm J000 screws securing the viewfinder.
    • Remove the viewfinder cover.
    Not necessary to remove the viewfinder cover for mirror box
    Ziyang - 回复
  46. Nikon D7000 Shutter Assembly Replacement: 步骤 46 中的图像 1,1
    • Remove one 3 mm J000 screw from the bottom left side of the camera.
    Don't do this : you don't need to, it's useless
    Xavier - 回复
  47. Nikon D7000 Shutter Assembly Replacement: 步骤 47 中的图像 1,1
    • Remove two 6 mm J000 screws from the left of the shutter.
    Not necessary
    Xavier - 回复
  48. Nikon D7000 Shutter Assembly Replacement: 步骤 48 中的图像 1,1
    • Remove two 6.5 mm J000 screws from beneath the lens mount.
  49. Nikon D7000 Shutter Assembly Replacement: 步骤 49 中的图像 1,1
    • Remove two screws from just below and to the sides of the viewfinder.
  50. Nikon D7000 Shutter Assembly Replacement: 步骤 50 中的图像 1,1
    • Remove one 5 mm J000 screw from the top right of the camera.
  51. Nikon D7000 Shutter Assembly Replacement: 步骤 51 中的图像 1,1
    • Carefully peel back ribbon cable on the bottom left of camera.
  52. Nikon D7000 Shutter Assembly Replacement: 步骤 52 中的图像 1,2 Nikon D7000 Shutter Assembly Replacement: 步骤 52 中的图像 2,2
    • Remove the left front ribbon cable from top right of circuit board.
    The illustration indicates this connector to be tilted upwards. I did - and broke the female connector. As shown on the right hand picture, the same thing has happened during the dismantling forming the basis for this “ifixit” instruction.
    This ribbon should be pulled straight out - not lifted upwards
    Bored Nomore - 回复
  53. Nikon D7000 Shutter Assembly Replacement: 步骤 53 中的图像 1,1
    • Remove all three wire connectors.
  54. Nikon D7000 Shutter Assembly Replacement: 步骤 54 中的图像 1,1
    • Separate the shutter assembly from the camera body.
    This part left me in the lurch a bit, undid the top 2 screws holding the shutter in but there seemed more to undo to actually release the shutter.
    digimaan - 回复
    If you intend to replace the shutter assembly only, you need to loosen it from the “shutter house” (don’ know correct term); (It is possible to purchase new blades only, but it seems complicated, and a shutter assembly costs around 35USD from Asia.)
    There are 3 screws; 2 visible on the “top” of the shutter assembly and one hidden underneath some ribbons on the “underside”. Study the new shutter to identify the screws being part of of the assembly and the ones holding it to the shutter house. (3 screws as mentioned)
    The power leads for the electric motor must be loosened by soldering (red and black cables).
    A ribbon with 4 tiny soldering points has to be loosened with a sharp tipped soldering iron; If you don’ t feel competent; bring it to someone who can do the very delicate soldering - especially for connecting the new shutter assembly.
    Bored Nomore - 回复
    I have followed this guide. But 2 small bits of rubber have appeared. Not a clue from where. Any ideas?
    Paul Scott - 回复
结论
34等其他人完成本指南。
团队
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G6
3 名成员
创作了5篇指南
10条评论
Use a #00 Philips, not a #0, or you'll strip the screws. Also, there are two or three screws connecting the shutter assembly to the camera body, and its contacts are soldered on. So you need a soldering iron for the last step.
Michael Duncan - 回复
im gonna be trying this soon , how long did it take and how difficult is it ,,,
Dean Wilkinson - 回复
Guide not completed. Last step only shows removal of mirror box. Shutter assembly replacement not
Ziyang - 回复
Regardless of possibly a few missing steps, this is a great lesson of how to deal with shutter replacement on my own. Hats off !!
Mateusz Witek - 回复
How to reassemble diopter adjustment?
Jerome - 回复
Can anyone help me with diopter control I took it apart by accident I don’t know how to put it back- jsarmd@yahoo.com
Jerome - 回复
what model cmos battery
Mohamad Farid Ghazali - 回复
Great that you posted link to Youtube video.
I had not been able to find the repair manual for this model and your step by step intructions helped me on the doubs I had.
Thanks.
Claudio Lupayante - 回复
Done mine but I do confess I got help from a mate how repairs mobile phones and computers make sure you note where all the screws go wee kept them in order when removing them so you no where thy all go when re assembling it back together I don’t think I would try to do it myself wee did take some photos helped when rebuilding it back together it worked ok after maybe wee were lucky
George aitchison - 回复
Where do I purchase internal parts for Nikon D series cameras? Thank you
Tony V - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 55
总计 18,953
