跳转到主内容
加入维修社区 - 创建账户
Nikon D7000 Shutter Assembly Replacement
你所需要的
  1. Nikon D7000 Shutter Assembly Replacement, Motherboard: 步骤 1 中的图像 1,1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Shutter Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Shutter Assembly Replacement: 步骤 3 中的图像 1,2 Nikon D7000 Shutter Assembly Replacement: 步骤 3 中的图像 2,2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Shutter Assembly Replacement: 步骤 4 中的图像 1,1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Shutter Assembly Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Shutter Assembly Replacement: 步骤 6 中的图像 1,1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Shutter Assembly Replacement: 步骤 7 中的图像 1,1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Shutter Assembly Replacement: 步骤 8 中的图像 1,1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Shutter Assembly Replacement: 步骤 9 中的图像 1,1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Shutter Assembly Replacement: 步骤 10 中的图像 1,1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Shutter Assembly Replacement: 步骤 11 中的图像 1,1
    • Gently pull the SD card cover off.
  12. Nikon D7000 Shutter Assembly Replacement: 步骤 12 中的图像 1,1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Shutter Assembly Replacement: 步骤 13 中的图像 1,1
    • Carefully lift the back case off.
  14. Nikon D7000 Shutter Assembly Replacement: 步骤 14 中的图像 1,3 Nikon D7000 Shutter Assembly Replacement: 步骤 14 中的图像 2,3 Nikon D7000 Shutter Assembly Replacement: 步骤 14 中的图像 3,3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Shutter Assembly Replacement: 步骤 15 中的图像 1,2 Nikon D7000 Shutter Assembly Replacement: 步骤 15 中的图像 2,2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Shutter Assembly Replacement: 步骤 16 中的图像 1,1
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Shutter Assembly Replacement: 步骤 17 中的图像 1,1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Shutter Assembly Replacement: 步骤 18 中的图像 1,1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Shutter Assembly Replacement: 步骤 19 中的图像 1,3 Nikon D7000 Shutter Assembly Replacement: 步骤 19 中的图像 2,3 Nikon D7000 Shutter Assembly Replacement: 步骤 19 中的图像 3,3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Shutter Assembly Replacement: 步骤 20 中的图像 1,2 Nikon D7000 Shutter Assembly Replacement: 步骤 20 中的图像 2,2
  21. Nikon D7000 Shutter Assembly Replacement: 步骤 21 中的图像 1,1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Shutter Assembly Replacement: 步骤 22 中的图像 1,1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Shutter Assembly Replacement: 步骤 23 中的图像 1,1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Shutter Assembly Replacement: 步骤 24 中的图像 1,1
    • Lift the motherboard off.
  25. Nikon D7000 Shutter Assembly Replacement, Tripod Plate: 步骤 25 中的图像 1,1
    • Remove four 6 mm J000 screws securing the tripod plate.
  26. Nikon D7000 Shutter Assembly Replacement: 步骤 26 中的图像 1,1
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
  27. Nikon D7000 Shutter Assembly Replacement, Image Sensor: 步骤 27 中的图像 1,2 Nikon D7000 Shutter Assembly Replacement, Image Sensor: 步骤 27 中的图像 2,2
    • Disconnect black and white speaker cable.
  28. Nikon D7000 Shutter Assembly Replacement: 步骤 28 中的图像 1,1
    • Remove three 6 mm J000 screws securing the image sensor.
  29. Nikon D7000 Shutter Assembly Replacement: 步骤 29 中的图像 1,1
    • Carefully lift the image sensor plate out of the camera.
  30. Nikon D7000 Shutter Assembly Replacement, Shutter Assembly: 步骤 30 中的图像 1,1
    • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
    • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
  31. Nikon D7000 Shutter Assembly Replacement: 步骤 31 中的图像 1,1
    • Remove two 5 mm J000 screws from under the flash.
  32. Nikon D7000 Shutter Assembly Replacement: 步骤 32 中的图像 1,1
    • Remove two 3 mm J000 screws securing the front cover.
  33. Nikon D7000 Shutter Assembly Replacement: 步骤 33 中的图像 1,2 Nikon D7000 Shutter Assembly Replacement: 步骤 33 中的图像 2,2
    • Remove the front cover.
  34. Nikon D7000 Shutter Assembly Replacement: 步骤 34 中的图像 1,1
    • Carefully remove the port cover.
  35. Nikon D7000 Shutter Assembly Replacement: 步骤 35 中的图像 1,1
    • Deroute the microphone cable.
  36. Nikon D7000 Shutter Assembly Replacement: 步骤 36 中的图像 1,1
    • Remove one 4 mm J000 screw from the front.
  37. Nikon D7000 Shutter Assembly Replacement: 步骤 37 中的图像 1,1
    • Remove one 8.5 mm J000 screw from the battery compartment.
  38. Nikon D7000 Shutter Assembly Replacement: 步骤 38 中的图像 1,1
    • Remove the grip carefully.
  39. Nikon D7000 Shutter Assembly Replacement: 步骤 39 中的图像 1,1
    • Remove one 4 mm J000 screw securing the top case (under right strap hook).
  40. Nikon D7000 Shutter Assembly Replacement: 步骤 40 中的图像 1,1
    • Remove one 4 mm J000 screw securing the top case (under left strap hook).
  41. Nikon D7000 Shutter Assembly Replacement: 步骤 41 中的图像 1,1
    • Remove the sticker covering the diopter adjust screw.
  42. Nikon D7000 Shutter Assembly Replacement: 步骤 42 中的图像 1,1
    • Remove one 8.0 mm J000 screw.
    • Remove the Diopeter Adjust.
  43. Nikon D7000 Shutter Assembly Replacement: 步骤 43 中的图像 1,1
    • Remove the top case.
  44. Nikon D7000 Shutter Assembly Replacement: 步骤 44 中的图像 1,1
    • Remove the Black, Yellow, Green cable from the top case board.
  45. Nikon D7000 Shutter Assembly Replacement: 步骤 45 中的图像 1,3 Nikon D7000 Shutter Assembly Replacement: 步骤 45 中的图像 2,3 Nikon D7000 Shutter Assembly Replacement: 步骤 45 中的图像 3,3
    • Remove two 6.5 mm J000 screws securing the viewfinder.
    • Remove the viewfinder cover.
  46. Nikon D7000 Shutter Assembly Replacement: 步骤 46 中的图像 1,1
    • Remove one 3 mm J000 screw from the bottom left side of the camera.
  47. Nikon D7000 Shutter Assembly Replacement: 步骤 47 中的图像 1,1
    • Remove two 6 mm J000 screws from the left of the shutter.
  48. Nikon D7000 Shutter Assembly Replacement: 步骤 48 中的图像 1,1
    • Remove two 6.5 mm J000 screws from beneath the lens mount.
  49. Nikon D7000 Shutter Assembly Replacement: 步骤 49 中的图像 1,1
    • Remove two screws from just below and to the sides of the viewfinder.
  50. Nikon D7000 Shutter Assembly Replacement: 步骤 50 中的图像 1,1
    • Remove one 5 mm J000 screw from the top right of the camera.
  51. Nikon D7000 Shutter Assembly Replacement: 步骤 51 中的图像 1,1
    • Carefully peel back ribbon cable on the bottom left of camera.
  52. Nikon D7000 Shutter Assembly Replacement: 步骤 52 中的图像 1,2 Nikon D7000 Shutter Assembly Replacement: 步骤 52 中的图像 2,2
    • Remove the left front ribbon cable from top right of circuit board.
  53. Nikon D7000 Shutter Assembly Replacement: 步骤 53 中的图像 1,1
    • Remove all three wire connectors.
  54. Nikon D7000 Shutter Assembly Replacement: 步骤 54 中的图像 1,1
    • Separate the shutter assembly from the camera body.
结论
35等其他人完成本指南。
团队
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G6
3 名成员
创作了6篇指南
10指南评论
Use a #00 Philips, not a #0, or you'll strip the screws. Also, there are two or three screws connecting the shutter assembly to the camera body, and its contacts are soldered on. So you need a soldering iron for the last step.
Michael Duncan - 回复
im gonna be trying this soon , how long did it take and how difficult is it ,,,
Dean Wilkinson - 回复
Guide not completed. Last step only shows removal of mirror box. Shutter assembly replacement not
Ziyang - 回复
Regardless of possibly a few missing steps, this is a great lesson of how to deal with shutter replacement on my own. Hats off !!
Mateusz Witek - 回复
How to reassemble diopter adjustment?
Jerome - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 114
过去 30 天: 539
总计 22,255
