跳转到主内容
Nikon D7000 Motherboard Replacement
你所需要的
  1. Nikon D7000 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Motherboard Replacement: 步骤 3 中的图像 1,2 Nikon D7000 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Peel the rear rubber piece off with tweezers.
    This is not needed : if you don't touch this rubber & screw the SD card cover will come off at the same time that the back case.
    = Quicker and easier
    Xavier - 回复
  6. Nikon D7000 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
    Xavier - 回复
  7. Nikon D7000 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
    Concerning the diopter, it's wrong : D7000 also have a screw in it.
    See step 41.
    Xavier - 回复
  9. Nikon D7000 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Gently pull the SD card cover off.
    Attention! High voltage. After removing the memory card cover, remove the yellow sticker and use a 220 volt 15 watt incandescent lamp to discharge the capacitor.
    Rust Twentyone - 回复
  12. Nikon D7000 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Carefully lift the back case off.
  14. Nikon D7000 Motherboard Replacement: 步骤 14 中的图像 1,3 Nikon D7000 Motherboard Replacement: 步骤 14 中的图像 2,3 Nikon D7000 Motherboard Replacement: 步骤 14 中的图像 3,3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Motherboard Replacement: 步骤 15 中的图像 1,2 Nikon D7000 Motherboard Replacement: 步骤 15 中的图像 2,2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Gently pry and lift the left motherboard shield off.
    No need to remove shield. Risk of damaging clips holding shield.
    Ziyang - 回复
  17. Nikon D7000 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
    Ziyang - 回复
  18. Nikon D7000 Motherboard Replacement: 步骤 18 中的图像 1,1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Motherboard Replacement: 步骤 19 中的图像 1,3 Nikon D7000 Motherboard Replacement: 步骤 19 中的图像 2,3 Nikon D7000 Motherboard Replacement: 步骤 19 中的图像 3,3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Motherboard Replacement: 步骤 20 中的图像 1,2 Nikon D7000 Motherboard Replacement: 步骤 20 中的图像 2,2
    One more ribbon behind press down tab
    Ziyang - 回复
  21. Nikon D7000 Motherboard Replacement: 步骤 21 中的图像 1,1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Motherboard Replacement: 步骤 22 中的图像 1,1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Motherboard Replacement: 步骤 23 中的图像 1,1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Motherboard Replacement: 步骤 24 中的图像 1,1
    • Lift the motherboard off.
结论
9等其他人完成本指南。
Jed Chen
于04/01/15注册
1,796 声望
创作了3篇指南
团队
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G6
3 名成员
创作了5篇指南
5条评论
perfekt. Thank you! Had to replace the board because the GPS port was brocken.
Georges Hamlet - 回复
Hi, thanks for the detailed instructions! I just replaced my main board and the new one did not boot. The battery is charged, but the LCD shows nothing when battery is in and when the power is on. Is that a problem with the replacement main board or does it need to be programmed? I expected it to power up once the power is available.
serget - 回复
Have you resolved your issue?
Bhaskar vedula -
I get CLOCK with low battery indication . I checked internal battery health and I replaced with new battery on motherboard . Now with new battery in place I see voltage 3.12v and still camera does show CLOCK symbols with low battery. Please let me know if there is hard reset makes default configuration.
Bhaskar vedula - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 31
总计 5,937
