Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
At this point, the capacitor is visible and its exposed contacts are boxed in red in the second picture. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
Do not touch any of the exposed solder points under the grip, as the capacitor is attached in this area. The attachment points for the blue and pink leads of the capacitor are circled in yellow in the second picture.
In this step, you will de-solder the four wires pictured. Mark the wires with a sharpie or a paint marker to keep track of their locations, as each pair of leads is nearly identical.
De-solder the four wires boxed in red using the same procedure on the preceding step.
Do not apply too much heat to the joints as you de-solder, as the ribbon cable they are soldered to is extremely delicate and melts easily.
Eyepiece Remove/Instal Step 32. To remove or replace the eyepiece, the diopter adjustment slider should be pushed fully to the '-' setting; that is, towards the base of the camera.
