跳转到主内容
Nikon D5000 Back Panel Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Nikon D5000 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,3 Nikon D5000 Back Panel Replacement, Back Panel: 步骤 1 中的图像 2,3 Nikon D5000 Back Panel Replacement, Back Panel: 步骤 1 中的图像 3,3
    • The battery door has been removed for clarity, but is not necessary. See this guide for how to remove it.
    • Unscrew the eight Phillips #00 screws on the back panel:
    • Two 2.5x6mm screws above the screen.
    • One 3x6mm screw on the upper part of each side (two total; right side shown).
    • One 3x7.5mm screw on the lower part of each side (two total).
    • Two 3x4.5mm screws on the bottom.
  2. Nikon D5000 Back Panel Replacement: 步骤 2 中的图像 1,3 Nikon D5000 Back Panel Replacement: 步骤 2 中的图像 2,3 Nikon D5000 Back Panel Replacement: 步骤 2 中的图像 3,3
    • Pull the back panel up, then tilt it back. There will be two cables still holding it on.
    • Doing this will also release the connector cover on the left side. Set it aside for now, but remember to reinstall it later.
    • Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
    • This procedure also applies to all of the other ribbon cables in the D5000.
    • Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
结论
Jacob Rardin
于04/14/14注册
1,390 声望
创作了6篇指南
团队
Cal Poly, Team 13-28, Maness Spring 2014 Cal Poly, Team 13-28, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G28
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 67
