跳转到主内容
Nikon D3000 LCD Screen Replacement
你所需要的
  1. Nikon D3000 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Removal of the screws from the bottom will aid in the removal of the back as it loosens the bottom tabs of the camera back.
    • Remove three 3 mm x 2.5 mm Phillips head screws from the bottom right back of the camera bottom.
    • Remove one 3 mm x 5.5 mm Phillips head screw from the bottom left of the camera bottom.
  2. Nikon D3000 LCD Screen Replacement: 步骤 2 中的图像 1,3 Nikon D3000 LCD Screen Replacement: 步骤 2 中的图像 2,3 Nikon D3000 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Remove two 3 mm x 5.5 mm Phillips head screws from either side of the viewfinder.
    • Remove four 3 mm x 5.5 mm Phillips head screws above and below the USB port cover and above and below the SD card slot cover.
    • Remove two 3 mm x 4 mm Phillips head screws inside the SD card slot cover.
  3. Nikon D3000 LCD Screen Replacement: 步骤 3 中的图像 1,3 Nikon D3000 LCD Screen Replacement: 步骤 3 中的图像 2,3 Nikon D3000 LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Gently lift the back of the camera off, starting with the top first.
    • Lift off the bottom slightly to expose the ribbon connector connecting the back of the LCD screen to the motherboard of the camera and lift the black tab on the ribbon connector.
    • Pull the ribbon away from the connector to disconnect the back panel from the main body of the camera.
  4. Nikon D3000 LCD Screen Replacement: 步骤 4 中的图像 1,2 Nikon D3000 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Use the black plastic spudger to push the black tab towards the lower ribbon. The black tab on the smaller ribbon should slide out of place.
    • Lift the white tab on the larger ribbon.
    • Gently disconnect both ribbons.
  5. Nikon D3000 LCD Screen Replacement: 步骤 5 中的图像 1,2 Nikon D3000 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Remove six 5 mm x 4mm Phillips head screws , then remove the metal plate housing the LCD from the plastic camera backing.
    After removing the metal plate housing, the buttons in the plastic camera backing are not secure. Be careful not to tip the backing, or you will have buttons everywhere!
    Jason “Jay” Mohamed - 回复
  6. Nikon D3000 LCD Screen Replacement: 步骤 6 中的图像 1,2 Nikon D3000 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Cover the old LCD Screen with tape before removing to avoid broken glass if the screen cracks during removal.
    • Use the metal spudger to detach the LCD screen from the metal plate that is held down by the adhesive.
    • Install new LCD screen
    How to order lcd replacement. Thank you
    Bryan Petalver - 回复
结论
8等其他人完成本指南。
Randall Heath
于08/25/15注册
851 声望
创作了3篇指南
团队
USF Tampa, Team 14-7, Meier Fall 2015 USF Tampa, Team 14-7, Meier Fall 2015 的会员
USFT-MEIER-F15S14G7
4 名成员
创作了6篇指南
2条评论
Completed this project but now my camera doesn’t turn on. Advice?
Eddie Martinez - 回复
My D3000 camera will not display. I change the screen but it still will not display pls help what will i do now
emmanuel nwokocha - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 68
总计 10,123
