本指南有最近更改,您可查看未经巡查的最新版本。
简介
This installation guide will help you replace the motherboard of your Nikon Coolpix 4600. Before getting to the motherboard of the camera. You will need to remove the rear and front cases.9084 to follow the steps.
你所需要的
Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
Using a Phillips 00 screwdriver, remove all of the six screws.
Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
After disconnecting the data ribbon, you can now separate the back case from the front case.
With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen (left side of the screen will be glued down).
Insert plastic tool under the screen and gently pry up the left side of the screen until the glue seal is broken.
Locate and remove the four 4.25 mm screws on the motherboard using a Phillips 00 screw driver.
