当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
Remove the chrome side cover from the body of the camera.
Remove the four 3.2 mm screws on the bottom of the camera.
Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
Gently separate the back cover from the body of the camera.
The back casing will still be connected to the circuit board by a ribbon
Use the tweezers to disconnect the ribbon from the circuit board.
Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
Gently separate the front cover from the body of the camera.
The front casing will still be connected to the circuit board by a few wires
Remove the two 3.2 mm screws that hold the flash to the front cover.
Use the Spudger to remove the copper colored light bulb clip.
Remove the front cover entierly from the camera body.
Gently remove LCD ribbon from the mother board
The screen will still be connected to the mother board by two very small wires (black & red)
Desolder both wires from the mother board.
Refer to iFixit's solder/desoldering guide for the correct procedure to desolder the connection.
Separate the LCD screen from the rest of the mother board
取消:我没有完成这个指南。
与3其他贡献者
于09/14/11注册
116 声望
创作了5篇指南
徽章: 5
+ 2更多徽章
CUESTA-ZIPPERIAN-F11S1G6
2 名成员
创作了6篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 14
总计 1,324
