跳转到主内容
Nexus 9 Speakers Replacement
你所需要的
  1. Nexus 9 Speakers Replacement, Rear Case: 步骤 1 中的图像 1,3 Nexus 9 Speakers Replacement, Rear Case: 步骤 1 中的图像 2,3 Nexus 9 Speakers Replacement, Rear Case: 步骤 1 中的图像 3,3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Speakers Replacement, Battery: 步骤 2 中的图像 1,2 Nexus 9 Speakers Replacement, Battery: 步骤 2 中的图像 2,2
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Nexus 9 Speakers Replacement: 步骤 3 中的图像 1,1
    • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
    • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
    • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
  4. Nexus 9 Speakers Replacement: 步骤 4 中的图像 1,1
    • Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
    • After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
  5. Nexus 9 Speakers Replacement: 步骤 5 中的图像 1,1
    • The battery should now lift free of the tablet.
  6. Nexus 9 Speakers Replacement, Antenna Board: 步骤 6 中的图像 1,2 Nexus 9 Speakers Replacement, Antenna Board: 步骤 6 中的图像 2,2
    • This step is not necessary if you have already removed the battery.
  7. Nexus 9 Speakers Replacement: 步骤 7 中的图像 1,1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  8. Nexus 9 Speakers Replacement: 步骤 8 中的图像 1,1
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
  9. Nexus 9 Speakers Replacement, Speakers: 步骤 9 中的图像 1,1
    • Use a spudger or your fingers to remove the first speaker. The speaker may be heavily glued in and require heat to lift. Be careful as you can pull the speaker apart.
  10. Nexus 9 Speakers Replacement: 步骤 10 中的图像 1,1
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
  11. Nexus 9 Speakers Replacement: 步骤 11 中的图像 1,2 Nexus 9 Speakers Replacement: 步骤 11 中的图像 2,2
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  12. Nexus 9 Speakers Replacement: 步骤 12 中的图像 1,3 Nexus 9 Speakers Replacement: 步骤 12 中的图像 2,3 Nexus 9 Speakers Replacement: 步骤 12 中的图像 3,3
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
  13. Nexus 9 Speakers Replacement: 步骤 13 中的图像 1,1
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
  14. Nexus 9 Speakers Replacement: 步骤 14 中的图像 1,1
    • Use a spudger to remove the second speaker.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 19-11, Maness Winter 2015 Cal Poly, Team 19-11, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G11
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,216
