跳转到主内容
Nexus 9 Rear Facing Camera Replacement
你所需要的
  1. Nexus 9 Rear Facing Camera Replacement, Rear Case: 步骤 1 中的图像 1,3 Nexus 9 Rear Facing Camera Replacement, Rear Case: 步骤 1 中的图像 2,3 Nexus 9 Rear Facing Camera Replacement, Rear Case: 步骤 1 中的图像 3,3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Rear Facing Camera Replacement, Battery: 步骤 2 中的图像 1,2 Nexus 9 Rear Facing Camera Replacement, Battery: 步骤 2 中的图像 2,2
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Nexus 9 Rear Facing Camera Replacement: 步骤 3 中的图像 1,1
    • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
    • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
    • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
  4. Nexus 9 Rear Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
    • After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
  5. Nexus 9 Rear Facing Camera Replacement: 步骤 5 中的图像 1,1
    • The battery should now lift free of the tablet.
  6. Nexus 9 Rear Facing Camera Replacement, Antenna Board: 步骤 6 中的图像 1,2 Nexus 9 Rear Facing Camera Replacement, Antenna Board: 步骤 6 中的图像 2,2
    • This step is not necessary if you have already removed the battery.
  7. Nexus 9 Rear Facing Camera Replacement: 步骤 7 中的图像 1,1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  8. Nexus 9 Rear Facing Camera Replacement: 步骤 8 中的图像 1,1
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
  9. Nexus 9 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 9 中的图像 1,2 Nexus 9 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 9 中的图像 2,2
    • Remove the three 3mm T5 Torx screws.
    • Remove the five 2 mm Phillips #000 screws.
  10. Nexus 9 Rear Facing Camera Replacement: 步骤 10 中的图像 1,2 Nexus 9 Rear Facing Camera Replacement: 步骤 10 中的图像 2,2
    • Using your fingers, pull up on ribbon connector to expose another ribbon connector below.
    • Remove the two 2 mm Phillips #000 screws on top of the second ribbon connector.
    • Pull up the ribbon connector with your fingers.
  11. Nexus 9 Rear Facing Camera Replacement: 步骤 11 中的图像 1,2 Nexus 9 Rear Facing Camera Replacement: 步骤 11 中的图像 2,2
    • With both ribbons out of the way, you can now lift the motherboard off of the tablet with your hand.
    • The camera is attached to the back side of the motherboard via a ribbon cable.
    • Use a spudger or your fingernail to disconnect the camera from the motherboard.
    • There is a small board that comes off easily with the camera. It is attached to the camera with a ZIF connector, and will need to be swapped over to the replacement camera.
结论
4等其他人完成本指南。
Sergio Vargas
于01/22/15注册
310 声望
撰写一个指南
团队
Cal Poly, Team 19-11, Maness Winter 2015 Cal Poly, Team 19-11, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G11
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 5,784
