跳转到主内容
Nexus 9 Power and Volume Buttons Replacement
你所需要的
  1. Nexus 9 Power and Volume Buttons Replacement, Rear Case: 步骤 1 中的图像 1,3 Nexus 9 Power and Volume Buttons Replacement, Rear Case: 步骤 1 中的图像 2,3 Nexus 9 Power and Volume Buttons Replacement, Rear Case: 步骤 1 中的图像 3,3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Power and Volume Buttons Replacement, Battery: 步骤 2 中的图像 1,2 Nexus 9 Power and Volume Buttons Replacement, Battery: 步骤 2 中的图像 2,2
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Nexus 9 Power and Volume Buttons Replacement: 步骤 3 中的图像 1,1
    • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
    • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
    • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
  4. Nexus 9 Power and Volume Buttons Replacement: 步骤 4 中的图像 1,1
    • Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
    • After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
  5. Nexus 9 Power and Volume Buttons Replacement: 步骤 5 中的图像 1,1
    • The battery should now lift free of the tablet.
  6. Nexus 9 Power and Volume Buttons Replacement, Antenna Board: 步骤 6 中的图像 1,2 Nexus 9 Power and Volume Buttons Replacement, Antenna Board: 步骤 6 中的图像 2,2
    • This step is not necessary if you have already removed the battery.
  7. Nexus 9 Power and Volume Buttons Replacement: 步骤 7 中的图像 1,1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  8. Nexus 9 Power and Volume Buttons Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
  9. Nexus 9 Power and Volume Buttons Replacement, Motherboard: 步骤 9 中的图像 1,2 Nexus 9 Power and Volume Buttons Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Remove the three 3 mm T5 Torx screws.
    • Remove the five 2 mm Phillips #000 screws.
  10. Nexus 9 Power and Volume Buttons Replacement: 步骤 10 中的图像 1,2 Nexus 9 Power and Volume Buttons Replacement: 步骤 10 中的图像 2,2
    • Using your fingers, pull up on ribbon connector to expose another ribbon connector below.
    • Remove the two 2 mm Phillips #000 screws on top of the second ribbon connector.
    • Pull up the ribbon connector with your fingers.
  11. Nexus 9 Power and Volume Buttons Replacement: 步骤 11 中的图像 1,1
    • Gently lift the motherboard up from the device.
  12. Nexus 9 Power and Volume Buttons Replacement: 步骤 12 中的图像 1,1
  13. Nexus 9 Power and Volume Buttons Replacement, Power and Volume Buttons: 步骤 13 中的图像 1,1
    在这个步骤中使用的工具:
    • Using your tweezers, gently grasp the clear rubber backing and pull outward. The buttons should come free.
结论
2等其他人完成本指南。
Alden Simmer
于02/05/15注册
370 声望
撰写一个指南
团队
Cal Poly, Team 19-11, Maness Winter 2015 Cal Poly, Team 19-11, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G11
5 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 2,025
