跳转到主内容
加入维修社区 - 创建账户
Nexus 5X Front-Facing Camera Replacement
你所需要的
  1. Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: 步骤 1 中的图像 1,3 Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: 步骤 1 中的图像 2,3 Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: 步骤 1 中的图像 3,3
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
    询问修复机器人
    添加评论
  2. Nexus 5X Front-Facing Camera Replacement, Rear Panel: 步骤 2 中的图像 1,3 Nexus 5X Front-Facing Camera Replacement, Rear Panel: 步骤 2 中的图像 2,3 Nexus 5X Front-Facing Camera Replacement, Rear Panel: 步骤 2 中的图像 3,3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
    添加评论
  3. Nexus 5X Front-Facing Camera Replacement: 步骤 3 中的图像 1,3 Nexus 5X Front-Facing Camera Replacement: 步骤 3 中的图像 2,3 Nexus 5X Front-Facing Camera Replacement: 步骤 3 中的图像 3,3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
    询问修复机器人
    添加评论
  4. Nexus 5X Front-Facing Camera Replacement: 步骤 4 中的图像 1,2 Nexus 5X Front-Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
    询问修复机器人
    添加评论
  5. Nexus 5X Front-Facing Camera Replacement, Midframe: 步骤 5 中的图像 1,1
    • Remove the ten 3.6 mm Phillips screws that secure the midframe.
    添加评论
  6. Nexus 5X Front-Facing Camera Replacement: 步骤 6 中的图像 1,2 Nexus 5X Front-Facing Camera Replacement: 步骤 6 中的图像 2,2
    • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
    添加评论
  7. Nexus 5X Front-Facing Camera Replacement: 步骤 7 中的图像 1,2 Nexus 5X Front-Facing Camera Replacement: 步骤 7 中的图像 2,2
    • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
    询问修复机器人
    添加评论
  8. Nexus 5X Front-Facing Camera Replacement: 步骤 8 中的图像 1,2 Nexus 5X Front-Facing Camera Replacement: 步骤 8 中的图像 2,2
    • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
    • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
    询问修复机器人
    添加评论
  9. Nexus 5X Front-Facing Camera Replacement: 步骤 9 中的图像 1,2 Nexus 5X Front-Facing Camera Replacement: 步骤 9 中的图像 2,2
    • Make sure all the clips are free.
    • Carefully remove the midframe.
    询问修复机器人
    添加评论
  10. Nexus 5X Front-Facing Camera Replacement, Battery Disconnect: 步骤 10 中的图像 1,2 Nexus 5X Front-Facing Camera Replacement, Battery Disconnect: 步骤 10 中的图像 2,2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
    询问修复机器人
    添加评论
  11. Nexus 5X Front-Facing Camera Replacement, Front Facing Camera: 步骤 11 中的图像 1,2 Nexus 5X Front-Facing Camera Replacement, Front Facing Camera: 步骤 11 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the front-facing camera flex cable.
    询问修复机器人
    添加评论
  12. Nexus 5X Front-Facing Camera Replacement: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the front-facing camera from its recess.
    询问修复机器人
    添加评论
结论
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
取消:我没有完成这个指南。
3等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 57
总计 2,782
